8" mids in front doors?
Has anyone actually done this? I have a set I would like to install....
cutout diameter is 7.3 inches
mounting depth is 3.7 inches
I am hoping it would be a simple install
I looked through a number of threads , but couldn't find anyone who has actually done it
Re: 8" mids in front doors?
lookey here....
https://www.scionlife.com/forums/viewtopic.php?t=225789
hey Fred... werent you supposed to make you & I aset of custom grills a while back?? what happened to ya???? jh
it will be in a 2-way- for now I will be using a Seas L22rnx/p
and possibly down the road when they come out with it an Image Dynamics XS8 -
the 8" will play up to about 1Khz and mated with a set of Image Dynamics Ultra Horns
If you're going to do that, I'd recommend going active. Run a 4 channel amp to your front stage. Use either the front or rear channels for the horns, then the other set for the midbass 8's. That way you can set your gains conservatively for the horns to help prevent damage!
Had to throw in my $0.02...
thanks..... they will be run active......would cost way too much to get a passive crossover designed for these....much easier to go active.
at this point the plan is to run some Zapco's
DC360.4 - bridged to midbass
DC500.1 - to sub
and for the horns I have another DC360.4.... will probably use 2 channels for the horns, and maybe leave the other 2 channels for future use
DC500.1 - to sub
I will post pics when it is done.
as far as speakers and stuff there are lots of great stuff out there, just depends o your budget and how you want to install.
for s simple passive set the Pioneer PRS720's have received great reviews.... as well as a number of others and for amps choose something well designed..... I think the JBL or infinity reference are a great deal, but they are huge.
I love the DLS set I am running, but they can get expensive...... I am going to be selling mine along with my custom kick panels and a pillars
Originally Posted by Zsanz
I'd like to see some pics when ur done lol.
Anyone reccomend a nice amp+speaker combo to replace the stock 6 1/2's and 5 3/4"
I can't hear any vocal over my subs
Team No Limitz
Yeah I did mine a while back. Someone posted the link to it already...
I got one of the guys that is on here every now and then to get in and listen to it this weekend. I spent hours with a RTA on mine. Sounds awesome in there. I have the second set for the rear doors. Just have not had time to do them yet.
DC500.1 - to sub
DC500.1 - to sub
yep, looks good..... would love to hear it.... bet it sounds nice..... I used your post to make sure mine would fit and then make sure I had enough room for the baffles I was having made..... sent it to my guy who makes them and he looked over to be sure.
once I get them I will be isntalling...thanks for posting
I will be going diy on this one..... I am a little worried about the horns since I have never done them...but I will give it a shot.
had a guy make the baffles for the mids - http://community-2.webtv.net/MarvsPlace/MarvsPlace/
he is an awesome guy who does great work.
my system has changed since the original install- I put my spare back in and went to one sub.
amps are a couple weeks out, but should fit my amp rack fine.
If Bing were closer and I was willing to wait I would probably have him do it again.....he does great work and I always recommend him
That is some serious equipment! You have a pretty nice ratio between your Seas mids and horns. Who is going to do the install? SimplicityinSound again, or are you going DIY?
DC500.1 - to sub
DC500.1 - to sub
Good ol' Marv. I've been over to his house a few times, but it's been a very long time since the last time. Very good guy and an even better cabinet maker.
Using the 8s and horns seems so simple, but for some reason, my mind tells me I'm gonna run into trouble somewhere. For me, it would probably be the EQ'ing part since I suck at that. Again, it seems so simple, but I know that's it's more ignorance on my part. Definitely good luck... I'd like to see this project go evolve so keep us up to date.
DC500.1 - to sub
DC500.1 - to sub
I am actually going to go with the mini bodies....after looking at placement and angles the mini's seemed like they would be better to avoid rain bowing off the gearshift console
I started to install my 8's and they are huge, plus I have a ton of deadener on there and cutting would be a pain, so I am going to find some nice 6.5's that will take a ton of power. Looking for some ID x65's right now
Is that you I see over on DIYMA?
I hear lots of good things about those x65's, I know u don't want to cut but 8's won't shake the doors as much.
As far as rainbowing, I was wondering about that too since the center console sticks way out there so I experimented with my USD's which are full bodies in the car playing down to 600hz and there wasn't any rainbowing whatsoever, everything was perfectly centered and seemed to extend out past the physical boundaries of the car.....it was SO nice. But once matched up with door mounted mids, may ruin the illusion I'm afraid, unfortunately the final install will tell.
Let me know how the mini horns work for you, I could always use the ones I have but really want to use the exteded range of the full bodies.
speaking as that guy, it sounds amazing! With OR without the subs on. The sound quality is just superb
DaBlackBox
134
04-10-2022 02:04 PM
shaefner
10-08-2003 02:48 PM
