Aftermarket shift knobs that fit??
Old 10-27-2012 | 04:37 AM
NastysXB's Avatar
Default Aftermarket shift ***** that fit??
Anyone have a aftermarket shift **** on there 5 speed? I want one that will just screw on a stock shifter with no mods. I like the trd one but want to no what else fits. thanks for any info
Old 10-27-2012 | 04:57 AM
jetas's Avatar
I had a home made bubble **** that i ran for a while. I found the drill bit and tap at pep boys for like $10 so i can just make a threaded **** if its a solid mateial
Old 10-27-2012 | 05:14 AM
xseveredveganx's Avatar
Utah Scions
Anything that threads on will fit...
Old 10-28-2012 | 04:09 AM
RevolutionAutomotive's Avatar
Scionetics
Any shift kn0b you find that is a 12x1.25 thread pitch will fit..
Old 11-28-2012 | 03:26 PM
TheMotrCty's Avatar
True, 12x1.25 thread pitch will fit. But I have a question:
I bought the **** I wanted but it just threads down the stick. The OEM is kinda like an upside-down pear with a sleeve (grey) attached to the bottom end so that it fits flush to the boot. With just a new ****, there is a 3" gap from the bottom of the **** to the top of the boot (there's a plastic insert at the top of the boot that grasps the stick). So, what can one use to "sleeve" down from the aftermarket **** to the top of the boot? It looks kinda stupid without something.
Just wonderin',
Ronnie
Old 11-28-2012 | 03:54 PM
jetas's Avatar
Slide the boot up towards the shift ****. I did that to mine. Looks akwards at first but you get used to it
Old 11-28-2012 | 04:10 PM
TheMotrCty's Avatar
I thought about that, but isn't the diameter of the plastic "stay" at the top of the OEM boot the wrong diameter to just "slide up" the stick? I think there's a notch in the stick where that stay seats.
Ronnie
Old 11-28-2012 | 04:15 PM
jetas's Avatar
It is a different diameter but the plastic piece will hold snug. I ran mine like that for a few months with no issues.
Heres how i had it
Old 11-28-2012 | 05:09 PM
TheMotrCty's Avatar
Heres how i had it
Done deal. Worked perfectly. Stuck a screwdriver in the expansion slot on the stay, slid it up the stick, put the OEM sleeve on top of the stay, screwed down the new **** and VIOLA! It's tight enough for me.
Thanks for the tip.
Ronnie
Old 11-28-2012 | 05:13 PM
jetas's Avatar
No problem bro.
Old 12-11-2012 | 12:59 PM
SKI's Avatar
SKI
I wanted a round shift **** instead of my RS 7.0 Lever handle. I had some black leather to cover the white plastic, I like it, Torque Solution shift ****, weighs almost nothing. Looks plain and sporty.
NonStopTuning
06-29-2015 08:42 PM
disaster06
02-03-2015 09:50 PM
Scionxa180
Scion xA Aero & Exterior
01-08-2015 09:33 PM
pro710
12-29-2014 07:52 PM
disaster06
12-26-2014 04:00 PM
