Battery Size
optima are the best batteries in the market but also the more expensive ones , the reason it's because the battery is completly sealed and instead of liquid acid uses acid in gel state which is virtualy imposible to have a leak and also instead of groups of lead plates it uses something like a lead sheets rolled this gives your battery more life time and its maintenance free but if you want sometin' cheaper but good quality, interstate 3478DT (green case ) would do the job
Originally Posted by buickid
Heh, don't worry, I'm pretty knowledgeable about car electronics. I plan on going with some Deka Intimidators, group 31, if they will fit. The alternator will come in as well.
Aaaaaand I'm in the midst of upgrading my stock alternator. The tC alt does in fact fit. BUT, you'll need to either pull the stock alternator pulley off your xB, but it has a clutch in it... Kinda weird... But www.nonstoptuning.com has a smaller pulley that will work perfectly!
Let me know what you come up with!
rain7905643
03-14-2015 12:48 AM
