Blue, White, or Green MODE light assembly.. will trade!
Old 04-03-2008 | 09:35 AM
  #41
MauiGideon's Avatar
Originally Posted by jimmbomb
Originally Posted by FlyinLow
Hey Jimmbomb,
I had originally gone down to Pep Boys and purchased their LED strip for install. Then I found this one at Oznium and returned the other one:
It is from Oznium. It has encapsulated PLCC's and should be easily twice as bright as the other one that I returned. I will post a new thread once I get all my parts back and get her put back together. The waiting is killing me.
hey Flyinglow... those are the exact same lights & got from Oznium too, but I got them in white. I am going to stick those up UNDER my mirrors pointing straight down & wire them to the dome light circuit. So when I hit the remote unlock at night & the doors unlock & the dome lights go on, these lights will shine down from under the mirrors & light up the ground where you step.. BUT I cant do that till the weather warms up.. It's been below 30 degrees here for 2 months now & I aint gonna mess with frozen plastic parts till I get 60 degreees.. You got a heated garage I could rent for 4 hours?? hahha hahahh ahha.... jh
Thats such a sick idea... dammm jh never cease 2 amaze me... You actually do this yet? Any pics?
I was looking at oznium and the circular one I was thinking that it would look cool in the right dash side... where there is like a little cubby hole... Hmm Any ideas?
P.S Are these the ones your talking about?
http://www.oznium.com/led-modules
Old 04-04-2008 | 03:34 AM
  #42
jimmbomb's Avatar
Yes that link to oznium are the ones we got. I havent put themin yet as it's been to cccccccccoooold here to pull the door panels off. I dont want to mess with stressing out frozen plastic clips as I am afaraid that they will break in some way, so I am waiting for at least 60 degrees to pull off the door panels & run my wires.....
So you want to put one of those in the dash?? on the right side..-passanger-..??? a cubby hole there?? hhhhhmmmmm I dont see one there, but i do see one on the left side. -drivers-. I think if you put one there shining 'up' it may be too bright aat night if you run it at night, but. you may want to stick it on ther & test it out....
I always hook up to a 9 volt battery first & then go for placement...... when I am happy with the look, & brightness, & direction & spread of the light, then I final install with a 12 vlt hook up..... so you may want to test first before drilling any holes or glueing.......... in my opion . yours may vary though........... good luck with your projects & remember to post pistures of your stuff. before during & after.......jh
Old 04-05-2008 | 07:20 PM
  #43
DJ_FroZone's Avatar
why am i disconnecting the battery
Old 04-05-2008 | 08:26 PM
  #44
jimmbomb's Avatar
Good Question, Brian.... why are you?? What have you got going on now????? jh
Old 04-05-2008 | 08:33 PM
  #45
DJ_FroZone's Avatar
it says disconnect the negative wire....
Old 04-05-2008 | 08:34 PM
  #46
DJ_FroZone's Avatar
is it so the irbag won't fly out?
Old 04-05-2008 | 09:21 PM
  #47
DJ_FroZone's Avatar
wtf the T30 screws won't come out, they won't loosen at all!! HOLY ____. what am i doing wrong.
Old 04-05-2008 | 10:19 PM
  #48
jimmbomb's Avatar
you dont have the socket in there all the way....... push the socket in there alone till you sink it in the screw & it catches.... then slip your extension on & then the ratchet...... make your ratchet go the correct direction BEFORE you put it on the extension... jh....... ps disconnect the negative BATTERY CABLE..from the battery first.......
Old 04-05-2008 | 10:37 PM
  #49
DJ_FroZone's Avatar
???/ i just have a screwdriver with a T30 head on it. so there is no ratcheting going here...is that gonna be a problem. it fit in the hole fine. so i should push in and then start turning?
Old 04-06-2008 | 12:38 AM
  #50
jimmbomb's Avatar
OH. You know what?? I am so sorry........... as outlined in the DIY, you may have skipped over the sentence.... check this out.. ""The Screw wont come out!!! It has a 'keeper' on it so it wont fall out.. it just comes loose & stays in there""..... Just loosen up both sides.. You'll feel the screw become jiggily..... then carefully lift the airbag/ horn assembly towards you, then set it up on the steeering wheel column just below the top of the steering wheel. leave all the wires hooked up to the air bag...... remember. the screws WONT come out!!!!!........ good luck dude....... shoulda called me..... jh
Old 04-20-2008 | 06:06 PM
  #51
jimmbomb's Avatar
bump
Old 04-21-2008 | 01:33 AM
  #52
FlyinLow's Avatar
Hey Jimmbomb,
I finally got those last two orange LED's swapped out that you pointed out to me (the traction control switch and the driver's window switch). Thanks again for pointing them out sir!
Have you don't your's yet?
Old 04-21-2008 | 11:08 PM
  #53
jimmbomb's Avatar
No, I had a bad experience with the SWI MODE button 1206........ I aing going that small... plcc is the smallest that I want to tackle anymore...so I'll leave them orage... UNLESS you want to do 'em for me.......... jh
Old 04-22-2008 | 12:35 AM
  #54
DJ_FroZone's Avatar
so how do i get to traction control?
Old 04-22-2008 | 01:49 PM
  #55
FlyinLow's Avatar
Hey Jimmbomb,
Let me get some more 1206's and I can do it for you no problem.
I had to work with the one in the door switch a bit to get the color even, but it turned out brighter than stock. I will take a pic today.
Old 04-22-2008 | 02:15 PM
  #56
FlyinLow's Avatar
Hey Frozone!
Just pull the lower trim panel off of the driver's side of the dash. Once you do that, you can just reach under and unclip the Traction control switch from the panel. Once it is out, flip it over and you will see that the PCB is just held in place with a couple of clips. Just pop it out gently and you will see the LED.
If you do this with the car on, your traction control indicator will come on and stay on even after you reinstall the switch. It can take up to a full day for it to turn back off. I had no problems during that time.
Good luck on the swap!
Old 04-23-2008 | 12:12 AM
  #57
jimmbomb's Avatar
Hey Jimmbomb,
SWEETNESS!!!!Have you done your Passanger side AIR BAG indicators too????... wow.. I may get rid of the orange after all.... Thanks Flyinglow.... jh
Old 04-23-2008 | 12:25 PM
  #58
FlyinLow's Avatar
Good morning Jimmbomb,
No, but I have been thinking about it. I have left all of the warning indicators in their factory colors so that the still stand out. If you want me to do yours too, I will pop the piece out to see which LED's it takes.
Old 04-23-2008 | 11:36 PM
  #59
jimmbomb's Avatar
Nawwwwwwwwww you know i kind of like the orange contrast to my all blue other stuff..... & seeing as how I back lit my window switche finger wells in blue, then the orange contrast of the 'auto' button looks good contrasting off the blue glow surrounding.. So I will leave sleeping dogs lie & leave it as is.. I am happy with what little orange I have left as it contrasts well with the blue.... thanks for the offer anyways, son.. I sure appreciate your effort & well wishes to help me out! You got a favor comming, my friend....... jyh
Old 04-23-2008 | 11:53 PM
  #60
FlyinLow's Avatar
You are just yanking my chain right?
You don't want it to look like this?
What did you use the backlight the finger wells bud? What a fantastic idea!
Thanks for the offer too. I may just take you up on it sir.
Quick Reply: Blue, White, or Green MODE light assembly.. will trade!
