Custom sub inclosure, new pedal kit and shift knob
I found this enclosure on eBay. Seems pretty reasonable on the pricing for all fiberglass, custom fit.
And it doesn't cover the pocket or the cargo net hold down, It holds a 10" Sub.
http://cgi.ebay.com/SCION-xB-Subwoof...QQcmdZViewItem
It was brought to my attention that I needed to check this thread. The sub is a 10w3v2 from JL audio. The enclosure is fiberglass. No panels were taken out. I designed it but didn't make it. I had everything done as in amps, speakers, head unit and headrest monitors so I can't really break it down as far as how much it cost for the enclosure alone unless I talk to the guy that made it. Hope this helps.....
Made mine myself pulled rear panel out and lined with plastic wrap . mixed up fiber glass resin and cut glass mat into squares.started appling in layers to make back added card board pieces in between layer for extra strength After it set removed from panel and reinstalled then made wooden speaker ring and suports. Then made face when set glassed both pieces together. wrap in carpet and installed into car.
NonStopTuning
06-29-2015 07:42 PM
