DIY Oznium.com 3rd brake light
xB2 Oznium.com 3rd brake light
Looking for a longer more visible 3rd brake light for your 2nd gen xB?
Look no further, Oznium.com has the solution.
Here's how to install it:
TOOLS NEEDED:
- Just your two hands
PRE INSTALL TIPS:
- SET PARKING BRAKE!!! (for safety)
*tech note: This install took me just over 5 minutes, minus taking all the pictures. I rate the difficulty of this install a 1 on a scale of 1-10, 1 being turn the key to "ON", and 10 being professional.
STEP 1: Open the rear hatch.
STEP 2: Remove OEM 3rd brake light.
- Start from either the left or right side.
- Using your hands carefully pull on the plastic housing removing it from the hatch.
- Look at the picture to help locate the 4 plastic retainer clips holding it in place.
- BE CAREFUL not to break the clips.
STEP 3: Unplug the light from the harness.
- Locate the clip and press down on it to remove. (see photo)
STEP 4: Install new light.
- Plug the wire into the new light.
- Align the 4 plastic retainer clips with the holes and push the light into place until you hear the clips “snap”.
- Check to see that all 4 clips are secure by gently pulling on the housing in those location.
STEP 5: Close rear hatch and enjoy the new light.
Here are a few photos of the OEM and the OZnium light side by side:
I hope this DIY helps you with your project.
-Andrew
Stay tuned form more DIYs in the months to come.
I did this last night. Wow! This was easier (and less time consuming) than installing new cupholder pads and it looks awesome. Scion should pay attention and make this standard for next year. Thanks for posting.
thank you.
If you like this one, check out my other DIYs
Shark fin antenna: http://www.scionxbforum.com/forum/showthread.php?t=50
4 piece grill install: http://www.scionxbforum.com/forum/showthread.php?t=54
xB2 IN CABIN short shifter:http://www.scikotics.com/forums/show...83#post2370683
WHA?? an in cabin SS?? YUP!!! click to see how and where to get it. ;)
NST Shifter cable bushings: http://www.scikotics.com/forums/showthread.php?t=296901
xBSciontist
06-18-2019 04:06 PM
VCUBoy714
Scion tC 1G ICE & Interior
01-05-2015 09:46 PM
crystaljukebox_com
12-16-2003 09:34 PM
