Help with some 8"s
Help with some 8"s
Which would be better for mid bass?
Kicker 08CVT84
8" 400W 4-Ohm Shallow-Mount Subwoofer
Technical Specification
Sensitivity: 84.8 dB
RMS Power Range : 200 Watts
Peak Power Handling: 400 Watts
Impedance: 4 Ohm
Low Frequency response: 30 Hz
High Frequency Response: 35000 Hz
Diameter: 8 Inch
Features
8" Shallow-Mount CompVT Subwoofer
Peak Power Handling: 400 watts
RMS Power Handling: 200 watts
IMPP woofer cone material
Santoprene surround
Suitable for marine use
Sprialead technology
Steel basket allows sub to keep cool
Priced per speaker
Subwoofers are usually come as a single speaker unless noted differently.
or
Kicker 04SSMB8
8" 350W 4-ohm Subwoofers
Sensitivity: 89 dB
RMS Power Range : 40-175 Watts
Peak Power Handling: 350 Watts
Impedance: 4 Ohm
High Frequency Response: 500 Hz
Diameter: 8 Inch
Features
Tri-Tech cone (sandwiched foam, polypropylene, and woven carbon fiber)
Santoprene rubber surround
low profile stamped steel basket
spring-loaded nickel-plated terminals accept heavy-gauge speaker wire
free-air capability
flush-mount depth 2-5/16"
Priced per pair
Kicker 08CVT84
Impedance: 4 Ohm
Diameter: 8 Inch
Features
Santoprene surround
Priced per speaker
or
Kicker 04SSMB8
Sensitivity: 89 dB
Impedance: 4 Ohm
Diameter: 8 Inch
Features
free-air capability
Priced per pair
