How to load custom .LKA files onto Scion Premium HU
So I downloaded the Pioneer OEL Screensaver application and made a few custom videos.
I then turned them into the proper .LKA files and burned them onto a CD-R.
I put the CD-R into my Premium Head Unit and nothing happens.
This is probably a really easy thing, but I cant find any instructions anywhere (i've used the search feature).
What am i supposed to do to load the customized screensavers onto the deck?
Well if thats the case, you may have to try a different CD-R brand, like TDK or Verbatim.
As long as you used the program, went to make LKA after you were done, and they showed up and you clicked write LKA. Then go into your burning program (hopefully nero) and burn to the root of the disk with the LKA as the file, and that should do it. (make sure to burn at the slowest speed possible to prevent mastering errors)
Originally Posted by AndreyCo
I got it burned on the CD just fine...but isn't there something i need to do on the head unit for it to load the files...?
Insert the disc containing the rewritten data into the CD loading slot.
Close the front panel.
Press SOURCE and hold until the unit turns off.
Press and hold EQ and Display buttons until the unit goes into download mode.
After FINISHED is displayed, press OPEN to open the front panel.
Press EJECT to eject the disc.
Ah thank you very much!
Car doesn't need to be in the ON position though.
Just turn off using the power button, then hold menu & multi selector. worked like a charm (too bad you can only have one .lka file per CD.
CONCRETETC
02-09-2015 08:05 PM
ScionLife Editor
12-06-2014 11:58 PM
ScionLife Editor
11-28-2014 11:10 PM
ScionLife Editor
11-20-2014 05:20 PM
burn, car, cd, custom, disk, files, lka, load, oel, pioneer, sacramento, scion, screensaver, screensavers, write
