Noob subwoofer install questions
I bought a Fusion subwoofer pack (speaker, enclosure, amp, lots of wires) and I have many questions about installing it. I'm handy with electronics, but haven't done much car audio.
First 2 questions:
Where's a good place to get the 12v for the amp?
Where's a good place to ground it?
First 2 questions:
Can anyone be a little more precise? I understand that I need to get 12v from the battery and ground to the chassis, but anyone have experiences that might help? I've looked for threads about it, but found none that provided this sort of detail.
just to make it easy
https://www.scionlife.com/forums/viewtopic.php?t=219151
before something goes arcy sparky
Im new to the Xb but i have installed a few systems in other cars. The 12v will need to come from the battery and be fused, then ran throught the firewall (i believe there is a grommet on the pass side behind the glovebox) and then all the way to the back. The ground can be bolted to any body or chassis point but will need to be no longer than 18in and you should grind away any paint in the area. If it has a remote turn-on cable you will have to find that in the radio's harness. The rca's will also have to come from your headunit.
Hope that helps!
Hope that helps!
Hope that helps!
Hope that helps!
Any advice would be greatly appreciated.
Originally Posted by Whispaz
your nipple should be near your armpit...
for realzzz though, push it from inside out. easy
I bought the Fusion EN-PK112 from Fry's for $150:
It took about 4 hours to install, and I've never done a sub before. It came with all the cables and fuses and such. It sounds very good with the premium HU. I velcro'd the amp to the carpet under the front passenger seat, the sub fits on one side in the back, facing rear. I didn't tie down the sub, it's just wedged up agains the back seat. Nothing has moved it so far.
I'm looking around for a good way to quickly connect and disconnec the sub for times when I need the storage space.
CPL_Radar
03-05-2015 05:42 AM
wiltonhall
01-28-2015 03:46 PM
TheRedBox
31
12-02-2003 04:53 PM
