Scion xB2 (2011 and up) : Dual Color LED Turn Signal Switchback
Scion xB2 : Dual Color LED Turn Signal Switchback (For 2011 and up)
Place an order from here..
Most of the time when you install the LED for the turn-signal, it will cause hyper flashing due to LED bulb drawing so little power that
relay thinks you have burnt out bulb and indicates by turn signal to flash faster.
It's simple plug and play relay, that will fix the hyper flashing (one relay will be able to control all the LED bulbs)
Located below the steering wheel column by the junction box
* Light pattern : White color with parking lights on, changes to amber with turnsignal (amber then off, repeating till turnsignal off) then changes to white
During turnsignal sequence, white color will stay off
Installation Guide
- This is a conversion kit that will convert 7440 socket to 7443 dual contact socket
- Dual color turn signal
- Includes 78 LED Bulb (39 LED that has hyper white and amber diode built into each LED)
- Comes with pair (two bulbs) and new sockets
- White color for parking lights, changes to amber for turn signal
- Less attention from cop and still be able to make the clean look
- 1 Year hassle free warranty
Installation Guide
I just installed mine, but I had to guess which color wires to connect--the pics you've provided show the passenger side, and the driver's side wires are yellow and white. I connected the blue wire on the new socket to the yellow wire on the car, and the black wire to the white/black stripe wire in the xB harness. The amber part works, but the white doesn't.
I alo sent you an email about getting matching bulbs for the lamp above the turn signal. Let me know what you've got and how to order them.
Thanks!
Thanks!
LEDMod,
Does this mean that the turn signal will act as another parking/driving light? will it stay on if you just leave the on switch on? If yes then I am def interested in this because when i bought my 2011 it had a 08-10 front conversion done, so the only light i have when my lights are on is the actual projector and the parking, not my turn. Id love to have it on.
LEDMod,
Which is how it is on 08-10 models...
Thanks, yea, it's not updated on the online store...
E-mail me at Sean@LEDmod.com
I can process your order manually..
Hoping to have them in 2 weeks..
But e-mail me your new address, so I can update your address.
Thanks.
