Steering wheel HELP
Old 11-24-2008 | 09:32 PM
ATxB's Avatar
Default Steering wheel HELP
Im doing some interior work and wanna take off the silver plastic pieces off the steering wheel. do they just snap in? how do i get them off? any help would be appreciated
and in the next couple of weeks my interior should be completly different.
Also how do i take the A pillars off since they have the airbags in them??
Old 11-24-2008 | 10:54 PM
VonStarINC's Avatar
Alan wrench pulls the airbag off, then a screw in each and then just pull, they have single pins that hold them in place, 2 small screws on the back of the buttons to remove the switchbox and mode button
Old 11-25-2008 | 12:54 AM
ninja929's Avatar
make sure you disconnect the battery. You dont want the airbag to accidentally go off in your face while working on it. better safe than sorry.
Old 11-25-2008 | 03:18 AM
DAILYXB-TYPE-R's Avatar
yep that really hurts.
i've seen it happen to someone on the street and the airbags just went out and knock the guy out. so definetly be very careful and good luck
Old 11-25-2008 | 01:43 PM
ATxB's Avatar
Thanks guys. Should have most of what i wanna do done before x mas. I will keep yall updated!
Old 11-25-2008 | 02:19 PM
sdsnybny's Avatar
Here is a good DIY for the Gen 1's it should be similar to this, hope it helps
http://www.xbsite.com/forum/howto-re...es-t-1098.html
Old 11-25-2008 | 02:31 PM
ATxB's Avatar
Thanks Steve. Im sure itll be similar to the Gen2
Old 01-12-2009 | 10:09 PM
Direness's Avatar
So you can't remove the silver pieces without disconnecting the battery and removing the center piece?
Old 01-12-2009 | 11:07 PM
jingjing's Avatar
nope, cause there is a screw that holds it in. once you take the airbag off, you can get to it. by the way, to take the airbag off, its a t-30 torx bit. make sure you disconnect the battery and leave it off for at least 90 seconds. there still a charge and if you mess with the wires for the airbag, you might set it off. i just put on a leather wrapped steering wheel and love the feel.
CombatmedicR56
11-12-2020 01:53 AM
fur_pig
03-20-2020 04:28 PM
bootlgr
01-26-2016 01:22 AM
FurionAlpha
Scion tC 1G ICE & Interior
01-12-2015 08:25 PM
Beesh
01-09-2015 06:30 PM
Quick Reply: Steering wheel HELP
