What would it cost, and would it be worth-while?
Old 04-21-2009 | 11:12 PM
Invertalon's Avatar
Default What would it cost, and would it be worth-while?
Hey guys,
I have the stock unit in my xB and really don't have too much of a problem with the stock audio. However, at some times I wish I could have a bit more "punch" and better midrange. If I were to replace the front two speakers in each door, could I do this fairly cheaply and not have to buy additional amps, etc.. Also, would the sound improve that much putting in fairly high-end, all purpose speakers?
What speakers would you guys suggest for this? I want a full sound and speakers that will replace the stock speaker fairly easily.
Just looking for ideas now and general research so appreciate your opinions!
Old 04-21-2009 | 11:17 PM
randomsuper's Avatar
you'd be better off changing the headunit than the stock speakers if you're looking for fuller sound. replacing the factory speakers and keeping the stock headunit tends to weaken the bass imo.
Old 04-22-2009 | 12:19 AM
IH8ONYU's Avatar
it's not a good idea to change out 2 front speakers and not do the rears as well, they will sound different, and mess up your sound stages... (it's not horrible to do, but each speaker responds better to certain freqs and you may make your sound issue worse and not get the result you want). To me, its like mixing mountain dew and sprite... will most people taste a difference? Some will, some wont, some will like the mix better, some will hate it... depends on how much of an audiophile you are...
i would say either get a better headunit, and "possibly" get a little better sound, or go ahead and get all new speakers and amplify them..
if it is a budget concearn, make sure you get a head unit you can return for full credit, because if you spend $ on the headunit and you dont like the way that sounds, you can return it, and save $ for better speakers and an amp..
Old 04-22-2009 | 12:28 AM
SquallLHeart's Avatar
always start audio work at the source.
Old 04-22-2009 | 01:00 AM
Invertalon's Avatar
Alright appreciate it guys!
yupinmytC
22
07-27-2024 07:08 PM
StxArOne
Scion xA Aero & Exterior
04-03-2018 02:22 PM
JonnyBigBoss
09-26-2015 08:31 PM
umnitza
09-01-2015 08:06 PM
Quick Reply: What would it cost, and would it be worth-while?
