Factory NAV system fix needed
Old 06-14-2007, 12:20 AM
  #41
BloodHoundFan's Avatar
Do you need to install the switch to watch DVD, or will just the parking break ground allow you to watch DVD. (trying to decide if I can do this one real quick prior to having the time to get behind the dash to do the rest)
Also, can you explain what each wire is that I am modifying ?
I assume the red wire is for a parking break ground?
What about the other 2?
BloodHoundFan is offline
Old 06-15-2007, 01:50 AM
  #42
Wagonistas
randode's Avatar
if you only do the parking brake wire (the red one), it will play dvds without the parking brake on. But as soon as you hit 1 mph, the display will black out, unless you cut and switch the purple wire.
randode is offline
Old 06-18-2007, 11:28 PM
  #43
skullsandcandy's Avatar
I bet you could use something like the PAC TR-7 to handle this.
skullsandcandy is offline
Old 06-19-2007, 12:04 AM
  #44
mcgong's Avatar
I just did this mod, this weekend and it works great. Thanks Randode. Now I just need a factory looking rocker switch make the installation more clean. Anyone know where I can find one?
mcgong is offline
Old 06-19-2007, 07:01 AM
  #45
LilwhitexB's Avatar
is there a posible way randode you could take a step by step pictures to make it more easy for some of us.
LilwhitexB is offline
Old 06-20-2007, 03:15 PM
  #46
Wagonistas
randode's Avatar
maybe. it's my wifes car, so i'll have to tear into it again when she's not looking.
randode is offline
Old 06-20-2007, 06:22 PM
  #47
I wish I had one available to try the TR-7 trigger module on it to see if it would bypass it like it does on the other Alpine decks. Anyone willing to try it out let me know :D
Old 06-21-2007, 12:08 AM
  #48
LilwhitexB's Avatar
thanx randode we will really apreciate your help.
Old 06-21-2007, 02:59 AM
  #49
brekdown59's Avatar
yes really nice write up,.. I will have my box in a few months..
question.............what does the MAP/VOICE button do.... does it have voice recognition.
brekdown59 is offline
Old 06-21-2007, 07:23 PM
  #50
mcgong's Avatar
if you goto trdsparks.com, there is an installation manual that you can download that has pictures of the installation of the nav. It was very helpful for me.
mcgong is offline
Old 06-22-2007, 02:36 AM
  #51
LilwhitexB's Avatar
yes but what i need is step by step pictures of how to make the navigation work while driving and change the adress while im driving and not need it to be park. same with how to play dvds while im driving with out being park to watch dvds. can anyone help please.
Old 06-22-2007, 08:47 AM
  #52
jackjon's Avatar
so i completed this mod tonight... not hard at all, but i had to buy a new socket set, as i could not find my 10mm socket to remove the nav!
dvd, ipod, nav entry all work great while in motion (when the switch is on). then simply flip the switch to resume navigation... this mod is well worth the effort. now if only navigating through the ipod menus was faster... i have too many songs and too many artists and it causes the menu in the nav to scroll slowly...
thanks randode!
jackjon is offline
Old 06-22-2007, 02:27 PM
  #53
mcgong's Avatar
I most drive with the switch off. The navigation still tracks where you are, and you have all the functionality of the unit. Then when I want the naviation to direct me, I just simply flip the swith back on.
Can you take a picture of where you put the switch. I put mine next to the gear shifter.
mcgong is offline
Old 06-22-2007, 05:23 PM
  #54
jackjon's Avatar
yah... i put mine right next to the stabalizer? switch... also where the fog light switch will go (the set of three switches right to the left of the steering wheel. i simply used the excess of that green wire that randode had us cut, fished it over the steering wheel to the area behind the nav, connected one end to one end of the purple line, and one end to the purple line going to the nave and there you go, i produced a two foot extension of the purple line. it worked spledidly. pics shortly...
jackjon is offline
Old 06-22-2007, 05:25 PM
  #55
I am going to do this mod as soon as my sirius stuff gets here since I can do everything while only taking things apart one time. Where are you getting your switches from? I really want something that fits in the switch openings and looks like stock. I think I would prefer to use the switch location next to the gear shift. Anyway, any leads/links to getting a perfect fit switch post it up!
Old 06-22-2007, 05:27 PM
  #56
brekdown59's Avatar
not a bad deal at all.
Old 06-22-2007, 06:06 PM
  #57
brekdown59's Avatar
just went to google and typed in rocker swiches and this came up
http://www.ittcannon.com/products/products.asp?pid=1027
tons of switches, not sure if any of them are able to be order by just buying one, but check it out tones of them.
i am thinking that you would have to buy these throgh someone like radio shack, but am not sure.
hope this helps, at least you can get some ideas
Old 06-23-2007, 03:08 AM
  #58
mcgong's Avatar
Here are a couple of pics of my installation.
mcgong is offline
Old 06-23-2007, 05:21 AM
  #59
Danielmaldonado's Avatar
i did this mod, and it seemed to make my navi lag quite a bit..anyone else have that problem?
Danielmaldonado is offline
Old 06-23-2007, 06:46 AM
  #60
jackjon's Avatar
nope... sure you connected everything back ok? if anything is loose, it could be separating when in motion...
jackjon is offline
Quick Reply: Factory NAV system fix needed
