Factory NAV system fix needed
#81
I just got an 08 tC with the SNS. I found this thread about the workaround and I am very interested in doing this. I wanted to clarify I few things so that I make sure this will work.
1 - Does this work for sure on the tC (2008 specifically)?
2 - Where exactly is the "red" parking brake wire? Randode mentions that it's "under the console" - what's the console he's referring to?
3 - So, does the "green" wire just needs to be cut and left hanging?
4 - When he says to "switch" the purple wire, does that mean run the purple to a switch, then do I run a power or ground to the other terminal(s) of the switch?
I have some electrical wiring background (not much), but it would be helpful to have pictures or at least diagrams. Any advice would be helpful. Thanks.
#82
The "red" wire will be located in proximity to your parking break handle.
I would cut the wire and cover the ends. (although you could get by without ever cutting this wire)
With the switch, just put a switch inline with this wire. So you can "cut" the signal and then "connect" the signal when needed. Basically making the "speed sensor" appear to be 0 to the SNS.
#83
Lotsa people gonna stump themselves trying to do this work around methinks.
Good advice on the AVIC D3 though. I had mine installed. Steering wheel controls work fine with the PAC-SWI adapter, and the bypass is simple.
#84
I'm in the process of doing this mod. I've just cut and grounded the RED wire (Parking Brake) and now the DVD will play while driving.
BUT...
I'm stumped as to which wire I need to get at for the Speed Sensor. There's only three PURPLE wires going into the back of the SNS - one of them comes out of a connector and is just cut off; one is like 16 AWG (thicker) and is in the connector to the far right (looking at the back from the top); the other is a thinner wire (18 AWG) and is in a ~20Pin connector on the far left (looking at the back from the top).
Can somebody please help me quick, I've got my center console apart now, and I'd like to get it all back together soon..
THANKS
BUT...
THANKS
#87
Anyone have p/n's , info on a rocker switch that will fit in the empty slot beside the Traction Control switch and the Fog Light switch ?
The empty switch slot beside the shifter is taken up by my Scion Security Glass Breakage Sensor..
#88
#89
Originally Posted by mrpsxplyr
UPDATE
I figured it out. It's actually NOT a PURPLE wire on the 2008 tC... It was a yellow wire on a 20 Pin connector going into the SNS.
I'm not sure if it's the same way on the xB, but I would be tempted say so, since it's the same system...
All I did was splice in an in-line switch (routing wire to the left side of the steering wheel) as BloodHoundFan suggested. THANKS!
#90
#91
Wagonistas
I have a small round rocker that works for the mod, but you gotta drill a hole in one of the switch covers.
if someone can post a pic of the wiring plugged into the back of the nav, I can point out which purple wire to cut and switch.
#93
Originally Posted by dseh1111
Has anyone tried the onscreen secret combination to eliminate the lock out, I posted the link for it up above. Please let me know if that works, it seems like it would be easier than cutting wires and adding switches..
#94
#95
Where do I get one and how much?
Thanks
#97
its the one on the right.
i sell them for $3 each. i'll get them up on the website today.
All I have to do is drill out the blank switch cover located beside the Trac & Fog switches just enough to slide the switch in?
In your pics, the one on the right side at the end looks kinda big, will it fit in the blank hole cover? All the switches you have listed are the same size?
Does the on/off one light up the "on" postion when turned on?
Thanks
#98
but from looking at screenshots of what this gives you, it doesnt look like it takes you anywhere that can bypass the lock out.
#99
Wagonistas
Thanks
#100
I ordered a replacement hazard/flasher lights switch from the dealer ($40!!) and put it in the extra slot to the right of where the original one goes. It was expensive, but it looks really slick and stock. I'll post a picture tomorrow
UPDATE: I tapped into power from the other one, so they both light up when my parking lights are on. I did have to bust out the dremel in order to flip it so that the "arrow" is pointing towards the passenger side (so the slope of the button matches)
