Factory NAV system fix needed
Old 08-13-2007, 02:44 AM
  #101
KevinTxB's Avatar
OK. Long story short. I had the viper 791 alarmed installed today at best buy and the installer accidentally pulled out two cables from the fuse box? They're green and purple wires that are pretty long and loose from any of the other wiring behind there. I BELIEVE these are the wires and randode specified to cut (green) and add a switch to (purple). Anyways, he didn't know how to put them back so he left it. Everything still works, but shouldn't I be able to watch dvds and type in addresses and whatnot while driving? Didn't he accidentally do randode's bypass? Oh yea, since all that was done i told him to ground the red wire already so i AM able to watch dvd's with the ebrake off. So umm...HELP.
sorry it wasn't that short of a story
KevinTxB is offline
Old 08-13-2007, 02:45 AM
  #102
KevinTxB's Avatar
oh yea. i forgot to specify that i am NOT able to watch dvds and type while driving.
KevinTxB is offline
Old 08-13-2007, 02:15 PM
  #103
Wagonistas
randode's Avatar
you just have to cut the purple wire behind the nav and install a switch, then it will work.
you are almost there.
randode is offline
Old 08-13-2007, 06:33 PM
  #104
KevinTxB's Avatar
So the cable that he pulled out is the wrong one? It's completely disconnected from the fuse box. So one side is connected to the nav I THINK, and the other is just dangling to the left of the steering wheel
KevinTxB is offline
Old 08-13-2007, 08:22 PM
  #105
k1tz1e's Avatar
They sell those rocker switches at Radio shack for like $4. Thats what I used except I have mine placed on the left of my steering column where the blank slots were.
k1tz1e is offline
Old 08-13-2007, 10:09 PM
  #106
KevinTxB's Avatar
ok i'm confused. whether i add a switch to the purple wire or not, isn't it not going to make a difference because it's disconnected? that's another problem. i dont even know where to plug it back in.
KevinTxB is offline
Old 08-14-2007, 05:15 AM
  #107
Televators's Avatar
I tried to enter the service menu (per the instructions at TRD Sparks), and couldn't get it to work.
I really want to get in there. I saw in the manual some sort of menu options for Bluetooth and Camera.
Televators is offline
Old 08-14-2007, 03:20 PM
  #108
DL
DL's Avatar
Originally Posted by dontrobme
I ordered a replacement hazard/flasher lights switch from the dealer ($40!!) and put it in the extra slot to the right of where the original one goes. It was expensive, but it looks really slick and stock. I'll post a picture tomorrow
UPDATE: I tapped into power from the other one, so they both light up when my parking lights are on. I did have to bust out the dremel in order to flip it so that the "arrow" is pointing towards the passenger side (so the slope of the button matches)
Thanks Randode, I don't see them on your site?
dontrobme, my Scion security glass breakage sensor is installed in that area.
DL is offline
Old 08-14-2007, 08:13 PM
  #109
KevinTxB's Avatar
sorry to keep on bugging you guys but I still don't know what to do about those cables. I checked that manual from trdsparks and all it says it that it is not necessary to plug in the purple cable. I am still not able to watch or type while driving
KevinTxB is offline
Old 08-14-2007, 10:14 PM
  #110
BloodHoundFan's Avatar
My recommendation would be to have them REPAIR the wires they pulled out of the fuse panel. Then from there do the mod on the wires for the SNS
BloodHoundFan is offline
Old 08-14-2007, 10:52 PM
  #111
Govt_Man's Avatar
Yeah, I never would have left their shop with items not the way they should be.
Govt_Man is offline
Old 08-15-2007, 02:06 AM
  #112
Wagonistas
randode's Avatar
you guys are looking at the wrong purple wire. the one you found is disconnected from the factory.
the wire you want is plugged into the back of the nav.
its the thin purple wire in a plug with a bunch of other wires.
this is the purple wire to cut and add the switch into.
randode is offline
Old 08-15-2007, 08:16 PM
  #113
KevinTxB's Avatar
OH ok. haha. GOTCHA. so can i just leave them the way they are then or should i go get them plugged back in? THANKS for all your help. I would be so lost otherwise.
KevinTxB is offline
Old 08-16-2007, 12:42 AM
  #114
Wagonistas
randode's Avatar
the wire you found was never connected. leave it how it is.
randode is offline
Old 08-20-2007, 11:05 AM
  #115
insaneintenti0n's Avatar
Sorry if this is a repeat question....
Not sure how many people played enough with their stereo before hacking it... do these fixes for the DVD and Nav system lock out also correct the MP3 CD Navigation lockout when you start driving?
That's what's been ____ing me off. It's kind of neat that you can navigate through the mp3 folders similar to the computer. Move up a folder, etc... but when you're driving you can't scroll the folder list. You get the first 4 (or whatever set you ended up on last.... so if you want a new folder while driving you just have to keep jumping tracks till you get it.
Looks to be tied in with speed, so i guess the GPS fix is going to be the same fix for this (the switch).
so far highly impressed with everything except the 'safety features'
insaneintenti0n is offline
Old 08-20-2007, 01:41 PM
  #116
The fix will correct that problem as well.
Old 08-23-2007, 05:15 AM
  #117
marving11's Avatar
Anyone know if Randodes fix voids the warranty? and if it does... what part of the warranty is voided? Whole thing?
marving11 is offline
Old 08-24-2007, 11:00 PM
  #118
Wagonistas
randode's Avatar
probably voids any electrical warranty.
randode is offline
Old 08-25-2007, 03:39 AM
  #119
NVMyTc's Avatar
So me and my buddy are trying to do this mod to his new Xb, but we need a little help...
1. Which purple wire do I cut, the one on the left or the right?
2. The green wire that I cut under the dash is the one that is not bundled with others wires correct? I found a single green wire above the fuse panel, im guessing thats the one.
3. Once I cut the correct purple wire, What prong do I solder the wire too?
Pic of switch from the front
Thanks guys
NVMyTc is offline
Old 08-29-2007, 05:18 PM
  #120
marving11's Avatar
Any OnScreen Override yet like the Lexus/Prius?
Quick Reply: Factory NAV system fix needed
