Gas Tank...
Gas Tank...
So is the xB's tank 12 gallons or 14... I know the book says 14 gallon but when I just filled up.. I knew my tank was empty... It said about 5 more miles till I was out... But yet when I filled up It stoped at about 11.5 gallons... so that leads me 2 believe it only has a 12 gallon tank... Anyone?
BTW... Gas is 4.09 in hawaii now... for REGULAR Jus happened today.. I had 2 share the pain...
Went 9.3 miles past Range = 0, took 12.213 gallons.
Went 13.2 miles past Range = 0, took 12.34 gallons.
Reset the trip computer when Range hit 0 to know how many miles past zero I went.
Here's somebody else's fill-up!
Originally Posted by DjEzE
i filled up full tank yesterday (with the car chocking for gas) and it came to 14.246 gallons
and here is a pic to prove it.
Wow I wish gas was that cheap here
Anywayz when I did my LED Gauge Swap.. I noticed the needle went below E... So when I put all my stuff back 2gether I put the needle right on or just a littleeeee below E... I noticed that when the gas light came on I had just a little b4 1/4th a tank left... So idk... Anyone else try this?
I'm sure GW had a little to do with it but didn't the major oil companies turn a huge profit? To the point where they were being investigated or questioned or something? I can't find the article I saw a week or two ago.
I drive till my comp tells me I have 15 miles left, and usually fill up within 2-3 miles either side of 0 (per the comp) and put in between 11.7 and 11.8 gallons.
I never have the guts to go that far on gas. As soon as the light turns on I usually try to find a gas station ASAP. Supposedly running on low fuel can be bad for the fuel pump causing it to overheat.
BlingSlade
11-20-2015 06:56 PM
JymmyTheSaint
08-26-2015 03:44 PM
