HID flicker and move on the road. What do i do?
Old 08-15-2010 | 02:09 AM
tonylunchbox19's Avatar
Default HID flicker and move on the road. What do i do?
So i just installed my hid kit on my 2011 xb. They flicker and move on the road like crazy. What do i do? Do i need a relay or is the hid kit bad?
Old 08-15-2010 | 02:45 AM
AAG's Avatar
AAG
DeepSouth Scions
Moving on the road means you didn't install them correctly. Flickering usually means a failing ballast.
Old 08-15-2010 | 03:48 AM
jnaval's Avatar
Where did you get your HIDs from?
Old 08-15-2010 | 04:52 AM
pyroman131's Avatar
Did you keep the rubber seal on the bulbs? If you don't have that on there, it won't be a tight fit in the housing. That can cause movement of the bulbs.
Old 08-15-2010 | 08:10 AM
papo's Avatar
where did you bolt the balast to? maybe its not tight, causing it to move and giving you a bad connection
Old 08-15-2010 | 01:14 PM
Th bulbs are put in right and everything is connected right. The car is still and im looking at the car and the lights flicker on the road. as if i was holding the bulbs wiht my hands. I got the mod express 1.7 kit. the guy told me that i need the harness. Will this fix it?
Old 08-15-2010 | 01:49 PM
egobuster1's Avatar
i always run a relay harness but that could fix your problem but if i had to guess its a cheap kit
Old 08-15-2010 | 04:45 PM
afterlifespecialist's Avatar
^^^^for the few extra bucks, the relay harness is the way to go. Though I doubt your problem is related to that, it sounds like your bulbs aren't sitting tight in the housing. I had a cheap kit before that I had this problem when driving. Upgraded to a better kit, and haven't looked back. Are both headlights doing it, or just one? If it's both, then I'd lean more towards thinking it's def. the bulbs not sitting right, as having 2 bad ballasts in the same kit is pretty bad luck.
Old 08-15-2010 | 08:40 PM
jnaval's Avatar
Like everyone said, try a relay harness. As for the bulbs moving, try to find a sized-up o-ring and sit that around the existing grommet, it might make the fit tighter.
Old 08-15-2010 | 11:10 PM
I ended up getting a new hid kit locally and hooked it up and it works fine. My friend told me it must be a bad ballast but both damn! lol Thanks so much for everyones help and ideas. Now on to the next mod!
Old 08-15-2010 | 11:28 PM
egobuster1's Avatar
i would still recommened the relay harness as they are prone to burning the stock wiring on cars with out the harness and can cause some serious electrical damage
Old 08-16-2010 | 01:02 AM
Yes my new hid kit came with a relay already. It looks great and i am very happy. As well i do recommend the relay.
Squishface
09-15-2015 06:51 AM
aprice95
04-28-2015 11:37 PM
GoodVibes
03-10-2015 04:29 AM
Switchbakz
12-01-2014 12:22 AM
Dylan
12
05-07-2004 06:22 AM
Quick Reply: HID flicker and move on the road. What do i do?
