installing anzo tail lights
Old 03-18-2010 | 12:46 AM
civtech96744's Avatar
Default installing anzo tail lights
i know this is probably a stupid question
but where do u put those wires that come out of the anzos?..do u hook them up to something?...
Old 03-18-2010 | 01:20 AM
RC-PILOT's Avatar
I assume you are talking about the LED style lights? If so, the wires are in place of your old light bulbs. Pull the old bulbs out, then look at the wires. They should plug into your vehicle harness. Mine are not Anxo, but that's how they worked.
Old 03-18-2010 | 01:24 AM
how do u pull out the bulb?..sorry im car mechanic illiterate....u jus pull it out of that socket? thing
Old 03-18-2010 | 01:38 AM
RC-PILOT's Avatar
Right. Take the bulb out of the original tail light first. Then pull the tail light off the vehicle. Now look at the new tail light assy and the the original bulb from the trunk area or through the tail light hole at the back, whatever works for you. Now with the key off, look at the new tail light assy wires and the socket where you take the original bulb off the wire harness. If these 2 don't fit together, then follow the vehicle wire a little further and see if there is another plug. If so, then pull it apart there and see if the wires from the new lights will plug in there. You will find it. It confused me for a minute too, then the little "!" went off above my head and I went back out and plugged them in. I did have to mess with the plugs and how I was plugging them in till I got the correct LED to light up with the blinker, breaks, and regulat tail lights. You will get it, just be sure to check it out before your done. I also found it better to zip tie or tape the final connections to be sure they didn't vibrate loose.
Old 03-18-2010 | 08:03 PM
DMC0585's Avatar
Dont the anzo tail lights have to be rewired, to prevent from blowing fuses?
Old 03-19-2010 | 01:12 AM
RC-PILOT's Avatar
Hmmmm.....instructions? Like I said I didn't get Anzo tails, so I may be way off for your application.
xBSciontist
06-18-2019 03:06 PM
TheTripleC
01-04-2015 06:46 PM
mrbadass03
24
04-21-2004 02:17 AM
Slopoke21m
10-02-2003 04:59 AM
randode
16
10-01-2003 12:40 AM
Quick Reply: installing anzo tail lights
