Unlock passenger and hatch door with one click of remote?
Old 07-29-2007 | 03:09 AM
xbtalk's Avatar
Default Unlock passenger and hatch door with one click of remote?
Is there a way to program the locks to unlock all doors with one click of the unlock button on the remote? I hate having to hit it twice. On my Toyota, with VIP alarm, I was able to make it unlock all doors with one click instead of two. I don't think the new xB has the VIP by default and I didn't see any info in the book about this.
Old 07-29-2007 | 03:57 AM
BloodHoundFan's Avatar
the factory keyless entry is not able to do this as far as I am aware. I haven't seen anything about any configuration options on the remote.
Old 07-29-2007 | 04:18 AM
Tomas's Avatar
Admin Emeritus
It would probably take a re-wire rather than programming, just like the original xB.
Tom
Old 07-29-2007 | 04:38 AM
Liquid-R1's Avatar
According to the manual, it can be done, but you must take it to the dealer to be programmed...
Old 07-29-2007 | 05:20 PM
SimpleNature's Avatar
I think it is done in the key.
Old 07-30-2007 | 12:50 AM
xbtalk's Avatar
So no open door close door turn key open door etc programming... that sucks!
Old 07-30-2007 | 02:25 AM
Whispaz's Avatar
i hope they come out with module to roll up and down your windows with the controls. I know they have them for vdubs (alientech)
Old 07-30-2007 | 08:05 AM
Linx's Avatar
Yes the manual does say it can be done by taking it to the dealer. What I want to know is can the doors be locked automaticaly once you start moving? The manual says it can be done for autos only but I can almost swear an old co worker of mine had that feature on his Tacoma. Though I know it isn't the same car but if it can be done with that, it should be able to be done with the XB
Old 07-30-2007 | 08:42 PM
Basilius's Avatar
I have an automatic and my doors lock when I start moving and unlock when I put the car in park.
I didn't request this, so I imagine it's standard (sic) behavior.
Old 07-30-2007 | 10:10 PM
Liquid-R1's Avatar
correct for autos. You cab also disable it or have them lock when you hit a certain speed. I don't recall but I think you can do that yourself.
Old 07-31-2007 | 05:49 AM
Linx's Avatar
But can this feature be done for m/t?
Old 07-31-2007 | 04:32 PM
Schmohey's Avatar
I think its for automatics only.
Old 08-01-2007 | 11:57 PM
Primo58's Avatar
No. Unfortunately it's tied to the shifting from Park to any gear on auto tranny's only.
Old 08-02-2007 | 01:38 AM
Govt_Man's Avatar
I'm curious why it couldn't be rigged for a manual transmission. Play along.
You get the factory nav system in a m/t. If you're moving, no DVD playback (without a work around). I don't see why this couldn't be hooked to a vehicle speed sensor, just like you could do with an automatic, having it programmed to lock doors at, say, 20mph. The sensor at the shifter, or wherever, for an automatic transmission, I would think, could just be bypassed or grounded, or switched, or however one would do it, so it would work the same for a m/t. It would be just like the nav system, grounding the parking brake and interrupting the VSS. Except you'd keep the VSS and ground the transmission sensor. No?
Old 08-02-2007 | 02:02 AM
Tomas's Avatar
Admin Emeritus
Most DVD playback interlocks are tied to the parking brake having to be on with a manual transmission (plus many DVD players now have gyro sensors built in to detect movement).
If connected in the same way it would mean doors locking with the release of the parking brake...
On the original xB (which didn't lock it's doors automatically) there was nevertheless a lead from the ECU to the "Door Lock Control Relay" module that delivered speed info to the module... Some owners have reported a "click" from the module at 20 MPH...
For all we know the original xB could have "auto-lock at 20" built in but not used. The xB2 may have the same. Sounds like some research is needed (as in monitor each lead from the DLC module and see if any change state at 20 MPH...).
Tom
Old 08-02-2007 | 02:12 AM
rsw1124's Avatar
I believe in the book the Autos Doors lock when Vehicle reaches 12 mph
Old 08-02-2007 | 02:54 AM
Okay! We have enough dealer types on this forum... FESS UP!!! How do we change the key to unlock ALL the doors with one push of the button?
Old 08-02-2007 | 04:25 AM
2008Xb's Avatar
I will check it out tomorrow with my techs and will get back to all of you on what I find out.
Old 08-02-2007 | 04:59 AM
Way cool, Tom... Thanks
Old 08-06-2007 | 01:48 AM
Default Calling Tom Scott...
Just in case you lost this thread... we still be waiting for info
Quick Reply: Unlock passenger and hatch door with one click of remote?
