Alignment After Drop
Here is my alignment report after installing Eibach Sportline springs.
The front caster and rear toe are out.
Anyone with experience think I have anything to worry about?
Front:
Spec. 5.0 to 6.5
Caster RF - 6.6* LF - 6.8*
Spec. -0.9 to 0.6
Camber RF - -0.3* LF - -0.1*
Spec. 0.0 to 0.30
Toe RF - 0.15* LF - 0.20*
Rear:
Spec. -1.9 to -0.9
Camber RR - -1.4* LR - -1.5*
Spec. -0.05 to 0.35
Toe RR - 0.65* LR - 0.45*
Front:
Spec. 5.0 to 6.5
Spec. -0.9 to 0.6
Spec. 0.0 to 0.30
Rear:
Spec. -1.9 to -0.9
Spec. -0.05 to 0.35
for best tire life , have actual spec in the middle of factory specs. but for performance . that will change , but in your case , your rear toe is way off will cause tire wear, are you sure you applied brake pedal while measuring caster? its off . cause.. brake pedal not applied proper when measuring caster, or alignment head not set proper. loose. or bent part. or wrong caster specs.
Used 09 specs. on 2011. Probably didn't change.
How do you go about adjusting rear toe?
You can't. The only adjustment that can be made to the stock suspension is front toe.
Front camber can be adjusted with after-market Eibach camber bolts.
Nothing else is adjustable unless you start looking into things like custom camber plates.
This is why I said to just do regular rotations and you'll be fine.
Was just wondering if there was a way to adjust rear toe.
Sgtfluffy16
Regional - Northeast
07-28-2021 10:32 PM
gedster314
Regional - Pacific South
02-19-2021 07:51 PM
ScionLife Editor
09-24-2015 10:50 PM
