Black and Yellow xB getting AIRREX Suspension w/ Stage 3 Digital..
LOL
just installed the all in one Stage 2 set up set up in my XB.. This must be the easyiest managment to install, did it in less than an hour with all the suspension already in. This is for a novice its that easy..
All you do is run power wire hoses and your done..
Over all performance of the kit... Ill give it a 8 .. works way better the other guys ones.. you know whos im talking about..
Pre set works well but still not as good at hight sensors but it does get you to the preset hight.
manual works fine.
Wireless is awsome! Flip the switch and pressure reading and controls all wireless.
Here is the pre made and wired box. 3 gallon tank, Viair 380c comp
Manifold valve.. Note Dakota Digital uses this same manifold . Guess where its made in TAIWAN!
In the boxed system the Brain has just the cuircut board no covers.
Viair 380c Compressor
Tank 3 gallon
Fitting and power and ground wires
manual works fine.
Tank 3 gallon
The WIRELESS air management on the AirREX AMS is by far the most simplest to install.. due to the fact that everything is contained in one box and prewired and plumed. the controller is and gauge is built into an all in one controller and because it is wireless.. no drilling and mounting of those 2 items.. The only thing you have to do is run the lines a power and ground wire and flip the switch and your management is working..
Guys that have no experience have done these installs in less than 8 hours.
we know that it does cost more than what you normally need. the benefits are you don't have to cut holes in the dash nor spend time mounting fittings tank and compressor and on top of that all the wiring and possible leaks many encounter..
here is a nice review on the kits.. it wasnt done in a Scion but has alot of info
http://www.airsociety.net/forums/sho...airrex+brownie
here is a video of the car in action
