Jack Stands
![10 Year Member](https://staticssl.ibsrv.net/autocomm/Content/ScionLife/SL_ten_year_badge.png)
![5 Year Member](https://www.scionlife.com/forums/images/misc/SL_five_year_badge.png)
Yea put them on the frame that's what I do is is safe.
For the front you can see place in the front that looks like the back put them there.
![Name: P2120497.jpg
Size: 104.1 KB](https://www.scionlife.com/forums/attachments/scion-xb-2nd-gen-suspension-handling-1795/101234d1501484354-jack-stands-p2120497.jpg)
__________________
__________________
That's a nice place to put it. I'm curious, after use, are there little dimples where the stand heads were touching the frame? I was thinking of using hockey pucks with little notches cut out so that the stand head is holding it firmly, and the puck is secure.
Also, when you're raising the car up, where are you placing the actual jack? In my old GTI, the lift points were crushed when not using the scissor jack. I'm afraid to mess these ones up as well.
No I didn't see any damage or marks when i took the jack stands out. It is a good strong frame LOL!! You are going to mess those points up where you put the jack cause they are mad thin and dont know why they fold but you wont tare up the frame.
Other than gravity, what's keeping the stands from sliding? The current set up seems a little slippery with metal on metal contact. Maybe even a rubber coaster would help.
If lifting the rear, setting the transmission into gear or park with wheel chocks. If lifting the front, setting the hand brake with wheel chocks. As for jack stand points, people put cloth, rubber, foam, carved out pieces of wood, and carved out hockey pucks. The wood and the hockey puck works well on the outer jack stand points, just carve a little groove for that metal flap and that will prevent it from bending, for the most part.
pjracer
11-21-2005 02:10 AM
