Rear Disc Issue
Old 09-28-2024, 02:58 PM
joeq's Avatar
Default Rear Disc Issue
Looking for advice with this problem. 2015 XB, rear wheels heating up.
With vehicle on stands, and still warm, calipers are not stuck. Can grab axle studs and turn rotors freely. However the assy is hotter than normal, (but not blueing), and a smell of brake material is noticed. More than normal. Brake operations are fine, with no complaints. Just the smell and heat radiating. Not sure if it only happenes while driving, and loosens up when not? It doesn't appear the parking brake is affecting it either.
My main concern is if I need to break open the fluid lines, is there an unusual proceedure for bleeding? I know some vehicals with ABS require some type of stagger bleeding, rather than the conventional 2 rears, and then the 2 fronts, (if needed to go that far). Is there a concern with the ABS system? Is there a pump, and/or control module that needs to be factored into bleeding? Thanks for any help.
joeq is offline
Old 09-28-2024, 04:20 PM
Super Moderator
SuperMod
MileHightC's Avatar
Bleed them same as always...
MileHightC is offline
Old 09-29-2024, 12:09 PM
joeq's Avatar
So I guess you're referring to standard practices of , right rear, left rear, right frt, and lastly left frt, while keeping an eye on the master cylinder, making sure it doesn't run dry. If only bleeding the back, then ignor the frts. And as for the ABS, no special concerns with any of the computer systems, or ABS components? If so, thanks for your reply.
joeq is offline
Old 09-30-2024, 05:09 PM
Super Moderator
SuperMod
MileHightC's Avatar
Same, same...no special procedures for the ABS.
Old 10-01-2024, 08:31 PM
joeq's Avatar
Gut-cha. Preciate it.
joeq is offline
Old Yesterday, 12:33 PM
RichBinAZ's Avatar
Are the rear wheels hotter than the front?
Should get about 6 clicks on the parking brake...
If you jack it up with the jack under the spring holder, do you get the same result?
RichBinAZ is offline
Redlandrebel
11
12-03-2016 06:59 PM
fxeditor
06-15-2015 08:56 PM
jastew71
07-23-2014 11:50 PM
Calypso124
03-28-2012 08:20 PM
SeanMG
Scion tC 1G Wheel & Tire
9
07-16-2010 11:51 PM
Quick Reply: Rear Disc Issue
