there's any difference between tanabe DF and NF
Old 01-19-2009 | 10:21 PM
pierre_tec's Avatar
Default there's any difference between tanabe DF and NF
i know the DF is for max lowering anfd the NF is for a suble drop but there is any diference in color..... cause i bought some DF off ebay any dont seem to be low enough, compare to some pics i have seen here looks a little high to me by the way the springs are red
Old 01-19-2009 | 10:35 PM
CIONIDE's Avatar
DF and NF are both red in color. Post a nice clean side view pic so we can see how low it looks.
Also, Tanabe charges more for the NF springs than the DF's, so nobody would send you the NF's on purpose if you ordered the DF's.
Old 01-19-2009 | 11:06 PM
IH8ONYU's Avatar
Also the springs will take a few weeks to fully settle.. They may appear high now, but will probly settle to the proper drop after 30 days time..
Old 01-20-2009 | 02:37 AM
pierre_tec's Avatar
no man i have like 6 month with the springs so i cant believe that they need to settle even more, also i havent take it to align, the top bolt of the struts is mark just like the factory setting, i dont know if that wolud be the reason but i give u the facts
Old 01-20-2009 | 03:25 AM
CIONIDE's Avatar
My NF's haven't "settled" at all from the original day I put them on. It won't affect your ride height, but you should definitely get an alignment. When I dropped mine, it drove perfectly straight, but the front negative toe was 3x the outer range of the factory specs; this would have led to excessively fast tire wear had I not done the alignment..
Old 01-20-2009 | 03:57 AM
ShaffNasty's Avatar
i havent gotten an alignment, but i am giving myself an excuse to buy new wider tires...
Old 01-20-2009 | 05:06 AM
CIONIDE's Avatar
If you're looking for excuses, I'm really good at helping others spend THEIR money.
Old 02-13-2009 | 05:53 AM
bb_ist's Avatar
tanabe springs are known not to settle. Their springs are fully compressed when they leave the manufacture
Old 02-20-2009 | 12:50 AM
Invertalon's Avatar
^^ I don't really believe that. I installed my NF210's the other week and am lower today than last week. It definitely settles.
From Tanabe website:
"Loading of the spring is part of the final testing process after production. Loading the spring compresses the spring to measure the strength and ensures tolerances within the spring's structure. Conventional loading processes load it to a maximum of only 50-70%, which causes a possibility of sagging and deformity. Using this machine, the spring is compressed 100% to determine that each spring has full function, and will never deform. By loading the spring to the full 100%, the spring is pre-engineered and tested to never sag."
Basically, it is pre-settled to an extent. More-so for performance and tolerance specs. I don't think it makes the spring 100% settled, but more to ensure the spring won't deform/sag like mentioned. Normal settling though with all the springs seems only natural however with more consistent use.
Old 03-03-2009 | 11:23 PM
BadBlood's Avatar
cionide keep helping me spend please if ya find nice rims let me know im open to suggestions....my question is with df's opposed to nf's how bad will i scrape rolling on 17's?
DJ_FroZone
25
05-30-2019 08:17 PM
xa007xa
02-22-2015 03:56 PM
Scionxa180
01-12-2015 04:42 PM
Besk_one
12-16-2003 06:25 AM
GreatWhitexA
10-21-2003 10:27 PM
