TRD Vs Tanabe Sustec Strut Brace
Old 03-24-2010, 08:42 PM
TrevorS's Avatar
OK, here's the installed photo. Still have to put the cowling and wipers back of course.
Final photo with everything back together. If you want flash, stay with the red, but for me -- this is perfect !
TrevorS is offline
Old 03-24-2010, 11:30 PM
Invertalon's Avatar
So do you notice any benefit with the bar installed now? ^^ The black does look good! Hope you installed it while the front end was up in the air to set the pre-load?
My Tanabe strut bar arrives tomorrow... First car mod I bought in a long time, and excited!
Will be installing it after work, along with putting my summer wheels back on. Yay!
I like the Tanabe design over the TRD due to pre-loading possibility. If I don't notice anything, at least it was just $100
Invertalon is offline
Old 03-25-2010, 01:38 AM
TrevorS's Avatar
Haven't driven it yet, but I installed it with the vehicle raised from the front center. I torqued the tower bolts lifting the tires off the ground. I then tightened the bar almost a full turn for preload, locked it, and then tightened the end bolts with both metric caps facing forward (had to reverse the driver's side). Looking forward to hearing your results !
TrevorS is offline
Old 03-25-2010, 02:50 AM
xb2_3o2's Avatar
hey man are you in Delaware?? let me know!
xb2_3o2 is offline
Old 03-25-2010, 06:31 AM
DJ_FroZone's Avatar
also how much it cost to spray paint n black? and tools for the install? im hoping to do this myself soon as well. i assume the instructiosn say all about the pre loading n such.
DJ_FroZone is offline
Old 03-25-2010, 05:22 PM
TrevorS's Avatar
Yep
The cost of a can of paint of your choice? Just remember to prep the bar first -- otherwise the paint won't stay.
To do it properly, you should remove the wipers and cowling -- the TRD Tower Brace install instructions include that procedure, as well as the strut nut torque (37 lb-ft), but they don't cover the Tanabe bar install so don't try to use them for that.
Tanabe provides a "MANUAL INSTRUCTION" sheet which is distinctive only for its uselessness. It told me nothing. My above description covers the adjusting. Just make sure the tires are touching the ground when you remove the strut nuts, otherwise the strut bolts will drop out of their holes. For jacking, I suggest level ground and a floor jack with the cup under the "ball" near the center of the front chassis cross member -- that portion is exposed and seems intended for jacking. (Don't jack any higher than necessary.)
Tower nuts require 14mm socket, bar lock nuts require 17mm open end wrench, and bracket bolts require 14mm socket or wrench and either a 6 or 7mm hex key (think it was 6mm). You'll also need an appropriate ratchet wrench and a torque wrench for the strut bolts. (You'll also need tools for the wiper and cowl assemblies removal -- they're in the TRD instructions.)
TrevorS is offline
Old 03-25-2010, 10:57 PM
Invertalon's Avatar
I just got done installing my Tanabe bar!
Install was fairly easy using TRD instructions. Only hang-up was with that larger, metal cowl under the plastic one which during reinstall was getting hung up on the little bracket hanging there, but once I removed that though it went right in. I used loctite on the strut nuts during reinstall (which as state above, will drop if the car is too high off the ground when you remove stock nuts to place bar bracket on!). The tanabe bar uses all three bolt positions versus TRD's two (so its free to move around). Just be careful of that and you will be fine. My bolts only wiggled though and didn't really drop at all.
I must say, I really like the cosmetic look as well after install. The tanabe is a nice red which looks great with the internals and my AEM CAI
I will get some pics up once I detail my engine bay, which it is due for!
Can't wait to test it out!
Old 03-25-2010, 11:48 PM
TrevorS's Avatar
Cool dude !
I'm not meaning to knock the Tanabe red, it's purely a question of personal choice. I tend to like mods that are low key in appearance and thereby help preserve the stock flavor. The only thing I've got that's red is the TRD sway bar and that isn't normally visible. I've taken the same approach with my Eclipse -- there're a few modest mods under the hood, but it still retains the OE flavor.
TrevorS is offline
Old 03-25-2010, 11:57 PM
Invertalon's Avatar
Oh for sure, totally understand! Taste is personal. I really dig the black as well. Id love either, haha.
Old 03-26-2010, 02:23 AM
TheFranchise's Avatar
Where did you guys find your best price on the Tanabe?
TheFranchise is offline
Old 03-26-2010, 03:23 AM
TrevorS's Avatar
Google !
TrevorS is offline
Old 03-26-2010, 07:37 PM
xb2_3o2's Avatar
cool man what part of the first state?? I work in Newark and Live down south..Hookin up my springs next weekend should be fun
xb2_3o2 is offline
Old 03-29-2010, 11:50 PM
Invertalon's Avatar
My bar installed:
Old 03-30-2010, 02:25 AM
TrevorS's Avatar
Looking sexy dude !
TrevorS is offline
Old 04-02-2010, 12:03 AM
TrevorS's Avatar
Finally got to take it out today! (Needed a battery charge and the ECU was disconnected a lot the last few days, so I wanted to get the relearning done -- a longish drive at various speeds ).
I'm no slalom driver so I'm not the one to give the brace a serious evaluation, but my impression is the steering is noticeably more stable than before. I've read that it improves steering wander and my impression is that's true. I was attributing that to the non-analog electric steering, but now I'm not so sure -- feels about right now, didn't before. Not a huge difference, but a welcome one -- I'd say the bar is worthwhile.
TrevorS is offline
Old 04-27-2010, 06:31 AM
CIONIDE's Avatar
Originally Posted by danielskshin
Looks good! I would have gone TRD
The TRD strut bar has the Toyota name, but costs a lot more, and offers no pre-load for the towers. Toyota sells it to people who don't know any better... they love people like you. It will hold it's value for people who want TRD stuff, but it's NOT the better bar for cost or performance.
End of discussion, you can stop your internal dialog now, you're wrong, get over it.
CIONIDE is offline
Old 05-12-2010, 11:14 PM
TheCor's Avatar
Just for the heck of it I'll throw this out there. DC Carbon Strut Bar. I had one of these on my 06 xA a few years ago and liked it. Looked real clean. I can't really comment on its performance though. Unless you have supporting suspension mods, it probably won't make a ton of difference. I had Eibach pro-kit and it handled well.
http://thmotorsports.com/dc_sports/d...SB1405-03-2010
TheCor is offline
Old 05-13-2010, 11:35 PM
Puredrive's Avatar
Or they sell it to people who want a decent part that will add a little performance and a unique element to their car without having to worry about warranty concerns.
Puredrive is offline
Old 05-14-2010, 01:05 AM
TrevorS's Avatar
http://thmotorsports.com/dc_sports/dc_sport_carbon_steel_strut_tower_bar/csb1405/i-290288.aspx?googlebase=CSB1405-03-2010
If I remember correctly, that was the one I was interested in getting for my xB2 because of the color; however, none was available as far as I could determine. I chose to go with Tanabe and Plasti-Dip instead !
Don't know, but it's clear among many Toyota/Scion owners TRD has a cache' factor, witness the appearance of TRD badges on exterior and/or interior. It only makes sense for a company to cash in on whatever cache' they can enjoy . No question, the enveloping Toyota warranty for TRD has to be attractive to many -- as always, a tough call! Still, for me, TRD is just another supplier and despite warranty considerations, there are others and warranty isn't necessarily everything -- clearly, it depends on the buyer !
TrevorS is offline
Old 05-14-2010, 02:11 AM
asiandude's Avatar
both the tanabe and trd bars are hinged...does anybody make a non-hinged unit?
asiandude is offline
Quick Reply: TRD Vs Tanabe Sustec Strut Brace
