$200 to move TPMS?
$200 to move TPMS?
I got a $200 quote from my local dealership to move the TPMS from my old set of wheels to my current already installed aftermarket rims. Is that a realistic price?
RON
RON
Sounds high, but basically you're paying to mount and balance 8 wheels. Typical price for mount/balance is $18-25/wheel. The dealer's at the high end. You may find someone to do it a little cheaper.
I'm assuming you want rubber stems in the stock wheels and that you plan to use them at some point. If not, they should only charge you for 4 wheels.
I'm just curious how much the TPMS sensors are outright...
Seems like it would be nice to have a set of nice wheels for the summer and use the stocks for winter. I know here in Utah they use salt on the roads. Up in Wyoming it's dirt.
I'd see it being easier just slapping on steelies with customs a lot easier than having to break everything down.
And you don't neccessarily have to get them rebalanced. If the tire shop is good enough and your wheels are already balanced well, they'll mark where the valve stem and the wheel weights are and go from there. I've done tires for too long! Lol!
Originally Posted by BloodHoundFan
to buy new TPMS sensors they are very pricey...somewhere between 3 and 5 hundred.
I'd be better off putting the TPMS in the 20's and leaving the stocks with nothing.
Tire Rack says
TPMS VALVE SENSOR
$344.00 for a quantity of 4 for new install on new wheels.
Probably the main reason most people just skip it.
I am also looking at places to swap my 07 sensors out and put them into my aftermarket wheels.
Does anyone know where I could do this for cheap (where did you go and how much you paid).
I think i would only pay maybe 120 bucks....
did any of you do this yourself? how hard was it and did you need any special tools.
thanks.
thanks.
Originally Posted by theGREEK
got my rims at discount tire and made sure the tpm system fit before i bought the rims. They fit and they charged me a few bucks to reinstall them on the new rims
so...houstonhelix....i just did exactly what you are looking to do. $200 is definitely pricey.
Call around local shops, they all quote a little differently, i found the lowest quote @ $110. but i ended up going to discount tire and they charged me $124 to install he new sensors. This includes all the mounting/dismounting fees and balancing of the new wheels.
Just a quik comparison, firestone wanted $250.=\
the charge is for the labor to reprogram the TPMS to your car. you can't just pull them and put them back on, they have to be recalibrated and reprogrammed. that's 50$ less than i pay my service department to swap wheels around on a car and i am the DEALER . . .
pay 'em to do it right, or you might regret it.
I did not have to reprogram my tpms (this was an extra 40 dollar charge which i opted not to do)
the reason i didn't have to was b/c i think both my tires had the same rated max psi. so there wasn't anything to change.
This is what i was charged for:
1)mounting/dismounting of tires to get to the tpms sensors (this will be more if you already have tires mounted on your aftermarket set since you will have to do an extra dismount)
2)very SMALL charge to physically move the tpms valve stems and pop them into your aftermarket rims. (this will be more if your aftermarket rims are not compatible and you have to buy a kit, most of the time this is not the case)
3)balancing the tires.
Go to shops that have done it before, otherwise they will not give you accurate quotes...discount tire is pretty good about it
Originally Posted by danoiboi
oh yea, and i've had mind for a few days now and no problems whatsoever, no tpms light....
i didnt have my sensors swapped in when i switched wheels, the light came on about two weeks later, stayed on for about two days.. and now its gone again( been about two more weeks)
so i have no clue whats going on. but i dont really care for it either.
