19" Infinity G35 Rims
Originally Posted by CIONIDE
Wow, I'm surprised that those wheels worked out with the offsets you gave. I would have expected them to stick out past the fenders. If you drop it, you may find out that you have rubbing problems. I also hope you used hubcentric rings. Looks good, other than needing to be dropped, if you can without rubbing. Can you post a daylight picture showing how they line up against the fenders? Thanks.
Thanks
I think this should just about cover the hub centric rings.
Couldn't have said it better myself.
Originally Posted by DiscountTireDirect
In a nut shell:
Hub centric rings help you center the wheel onto the hub and help keep the wheel centered while you drive. (this is very important especially under forces of speed.)
More in depth explanation of what hub rings are and what they do:
Your wheel has a, more or less, female hub and your vehicle has the male hub. Ideally you want the hub on your wheels to fit barely over the hub of your vehicle. (within .01mm) If they don't fit this tight you can actually torque them down off center which will cause a vibration and can lead to other problems while you drive. There is no industry standard for hub size. Scion uses a different hub size for each of their vehicles. Honda uses different sizes and so does Ford and Chevy for that matter. Most after market wheel companies want to make their wheels so they fit as many vehicles as possible so they build their hubs large enough to fit the largest vehicles hub. They then include or sell hub rings to fill the difference if your vehicles hub is smaller. EX: Konig uses as 73.1mm hub size for most of their passenger wheels you would need a 73.1-60.1mm hub ring for your 08xb.
I hope this helps and doesn’t confuse you more.
We also have a description in the Info Center section of our web site:
Info Center
Info Center
