My New 19" TRD's
Old 08-15-2007, 02:42 AM
uberspeed's Avatar
What do these weigh anyway? Tried searching, nothing came up.
uberspeed is offline
Old 08-15-2007, 04:18 AM
Bigfieroman's Avatar
One wheel on TRD Sparks shows a 28lb shipping weight, so, if that includes the box, figure about 25 lbs...if not, 28 lbs.
Bigfieroman is offline
Old 08-15-2007, 11:02 AM
Turbo4door's Avatar
Does anyone know what the Toyota recommended air pressure settings are for the TRD 19s? I figure a good starting point is probably still the factory front/rear PSI, but I would think the 19s would require a bit more pressure.
Thanks,
Dan.
Turbo4door is offline
Old 08-16-2007, 01:23 AM
uberspeed's Avatar
According to Ken from TRDSparks he says they're 30lbs. and they're on backorder, FYI
Old 08-16-2007, 02:45 AM
Holy poo!
Old 08-16-2007, 04:38 AM
uberspeed's Avatar
Holy poo!
Yep, waaay too heavy for me, regardless of looks.
Old 08-21-2007, 02:17 AM
lirandy's Avatar
looks real good!!!
lirandy is offline
Old 08-21-2007, 11:53 PM
trdpaul's Avatar
Thanks,
Dan.
Front - 39psi
Rear - 37psi
trdpaul is offline
Old 08-22-2007, 08:52 PM
Turbo4door's Avatar
Thanks,
Dan.
Front - 39psi
Rear - 37psi
Thanks. Is this published somewhere by Toyota, or just something you recommend? Either way, it pretty much follows what I had assumed. I took a guess, and have been running 37 front, 35 rear, and it has seemed to work well.
Dan.
Old 08-23-2007, 02:41 PM
trdpaul's Avatar
Thanks,
Dan.
Front - 39psi
Rear - 37psi
Dan.
If the dealership ordered the car with the TRD wheel option from the factory/port, it comes with a sticker that is applied to the door sill that covers the factory spec wheel/tire combo.
trdpaul is offline
Old 08-23-2007, 03:08 PM
Turbo4door's Avatar
They didn't/it didn't. I got the wheels a couple weeks after I already had the xB - so no sticker (yes, I looked before I even asked the original question). I did have the dealer swap over the TPMS sensors, and install the wheels, and I am pretty sure they are still supposed to apply the sticker - they didn't. Thanks for the info though.
Dan.
Old 08-23-2007, 05:40 PM
Revolt Imports
DeepSouth Scions
xbbox's Avatar
What size tire do they put on the 19" TRD's?
xbbox is offline
Old 08-23-2007, 06:14 PM
Turbo4door's Avatar
235/35R19 Toyo Proxies
Dan.
Old 08-23-2007, 06:26 PM
Revolt Imports
DeepSouth Scions
xbbox's Avatar
7.5" wide rim?
xbbox is offline
Old 08-23-2007, 06:59 PM
Turbo4door's Avatar
7.5" wide rim?
8"
Old 10-10-2007, 09:39 PM
GreenEnvy06's Avatar
Does that $2K from the dealer include the tires or no?
For that much I would assume they come with the tires.
I checked TRD Sparks and 4 wheels would run $929 shipped. Priced out a set of 235/35ZR19 XL Bridgestone Potenza tires that would run $729 shipped. Add in having them mounted and balanced and it's up around 2K.
If the dealer can have wheels/rims installed for $2K it's not bad going with that option from the dealer.
Also, I assume the factory TPS fit perfectly without any mods?
GreenEnvy06 is offline
rain7905643
06-13-2018 05:29 AM
airmankevin1
11-17-2015 05:44 AM
babyfac3pn01
10-19-2015 07:24 AM
terrye
09-26-2015 12:24 AM
Quick Reply: My New 19" TRD's
