Need help deciding on offset if runnings 19s
Hi, so i need some enlightenment...
Im deciding on a set of wheels mainly looking towards 19"s
whats the maximum width and offset can i run on 19s?? for front and back??
stock spring/shocks
would 19x9 +36 19x10 +42 work?
thanks@@
stock spring/shocks
thanks@@
19x8.5 +35 front & 19x9.5 +35 rear, maximum recommended width and offset, as long as you're on stock springs & shocks, or a mild drop like Tanabe NF210, Eibach Pro-Kit, or TRD springs. Personally I'd keep it at +40 offset front & rear for those wheel widths, but I know some people have pushed 'em out to +35 without being much past the edge of the fenders.
I know somebody who put on 19x9.5 +45 rears, and he had to add spacers because they hit the brakes and didn't clear. 19x10 +42 definitely won't work.
Are you looking at any wheels in particular?
Check out these pics of NoLimitz, he's on 19x8.5 +38 and 19x9.5 +38:
https://www.scionlife.com/forums/viewtopic.php?t=231642
Hey Silverx here's a link to my post. Im on 18x8.5 +35 offset all around, the back can be pushed out a little more with some spacers. The front wheels are as far as i would go to make sure u dont rub. https://www.scionlife.com/forums/vie...429&highlight=
oh and im on df210 now and I dont rub (maybe cause of my low low profile tires )
Just in case u decide to go with smaller wheels. I have also seen some pics on this site of an xb2 with some wide wheels with a low offset, just not 19...... I think 16 or 17. I think if we had some camber options we could run way lower offset 19" or 20" wheels".
{"Kregghill" This is the setup I went with...
19-8.5 +35 Offset Front w/235-35-19 General Exclaim
19-9.5 +45 Offset Rear w/265-30-19 General Exclaim (might need a 3-5mm spacer)????? }
https://www.scionlife.com/forums/viewtopic.php?t=219451
this will work.. its on ym friends car..
20 x 8.5 with +45 and a 20 x 9.5 with +45
he sits totaly flush and had to roll the rear fenders
https://www.scionlife.com/forums/vie...225499&start=0
10s in the i still think you can fit them with the right offset
Marshall, from that thread you posted the link for:
Did he end up changing offsets?
I know somebody who put on 9.5 wide +45 offset on the rears, and they hit the brake calipers. He added 5mm spacers to clear.
Originally Posted by islandxb2
Ok so I just ordered my wheels, 20 x 8.5 with a +38 and 20 x 9.5 with a +38. The wheels are 5Zigen Gravis1 in silver.
i just ordered a set of wheels
19x8 +32 and 19x9 +42
will post pic when i get them but its gonna take 2-3 months from japan
will i get any rubbing issue??
and what tire size/brand you guys recommend??
thanks
thanks
What wheels did you order?
225/35-19 fronts and 245/35-19 rears should be perfect with no rubbing, as long as you don't plan on a heavy drop. If you want a heavy drop, go down to 215/35 tires on the front.
There is a wide variety of tire choices for these sizes, but I am a big fan of Falken FK452's for wet & dry traction, handling, wear, and ride quality at a reasonable price.
got a set of works~ will post pic when it arrives
ya i proabably wont lower it any time soon
too many speed bump and pot holes everywhere i go
i'll look in to that tire
thanks for ur suggestion
anyone else?? it kinda rain alot here in vancouver so most likely make it a all season tires but then im keeping my stock so should i make it a summer tire only?
Besk_one
10-18-2003 08:41 PM
