New shoes finally---let me know what you think
Old 08-05-2008, 02:11 PM
c_dub's Avatar
Default New shoes finally---let me know what you think
c_dub is offline
Old 08-05-2008, 02:23 PM
Lehigh Valley Scions
metaldrumz's Avatar
Looks really good can you tell me the size
metaldrumz is offline
Old 08-05-2008, 02:28 PM
c_dub's Avatar
19X8.5 +35 235/35 front
19X9.5 +45 245/35 rear (plus 5mm spacer to clear the brakes)
c_dub is offline
Old 08-05-2008, 04:22 PM
BBN-Boys's Avatar
Looks GREAT!!! Luv the staggered look with FAT lips!!!
What spring/drop are you running?
Any fender rubbing issues?
I'm planning on running the same specs also, so your insights would be very helpful. Thanks
Wow!!! She does look awesome!
BBN-Boys is offline
Old 08-05-2008, 04:36 PM
c_dub's Avatar
Thanks!
I am on Tanabe NFs. The front tires rub a little when I hit a dip...not too bad though. You can't even see any scretches on the tires...so I would assume it minor rubbing. I have no rubbing issue at all in the rear...
Cionide has helped me a lot on a lot of my questions... Big thanks to Cionide!!
c_dub is offline
Old 08-05-2008, 05:16 PM
CIONIDE's Avatar
You're very welcome.
I friggin' knew it! I've seen many people post up that their 19x8.5 +35 with 235/35's don't rub on a Tanabe NF210, Eibach Pro-Kit, or TRD spring drop (all 1" front drops). I found it hard to believe, but I figured "Hey, they're doing it and say they don't rub, so it must be true."
I'm really sorry you're rubbing at all, I never want to give bad info. I guess the solution is to stay away from dips.
CIONIDE is offline
Old 08-05-2008, 05:25 PM
c_dub's Avatar
It's not major rubbing...I'm sure some camber or fender roll will cure that easy...
c_dub is offline
Old 08-05-2008, 05:47 PM
BBN-Boys's Avatar
I'll have a set of 19x8.5 +35 with 235/35's also......
I'll pray for no fender rubbing.....
Thanks for sharing your info.
BBN-Boys is offline
Old 08-05-2008, 05:53 PM
BBN-Boys's Avatar
BTW... newb here.
With the 5mm spacer, does that make the rear wheel offset to be +40??
CIONIDE would know this answer.
Thanks.
BBN-Boys is offline
Old 08-05-2008, 05:58 PM
CIONIDE's Avatar
Offset is the measurement from the inside of the wheel where it mounts to the hub, to the centerline of the wheel. The offset of the wheel doesn't change, the offset is still +45.
5mm spacers just push the wheels out another 5mm for clearance.
CIONIDE is offline
c_dub's Avatar
BTW... newb here.
Thanks.
Or you will get the same overall result with 19X9.5 +40 without any spacer... I used the spacer because the spokes were hitting my brakes so I added the 5mm spacer for clearance.
c_dub is offline
Old 08-05-2008, 06:03 PM
CIONIDE's Avatar
^^ Yeah, what he said.
CIONIDE is offline
Old 08-05-2008, 06:05 PM
BBN-Boys's Avatar
OK!... know I get it. That's what I thought.
Thanks guys.
BBN-Boys is offline
Old 08-05-2008, 08:31 PM
hwybox's Avatar
looks real mean I like it. from the back is the best view. nice!
hwybox is offline
Old 08-05-2008, 09:22 PM
cubanix's Avatar
i have 19X9.5 +40 no prob at all!!
cubanix is offline
Old 08-05-2008, 09:24 PM
BBN-Boys's Avatar
What tire size and brand of tire are you running?
BBN-Boys is offline
Old 08-05-2008, 10:16 PM
c_dub's Avatar
Thanks! but yeah...I really like the rear 3 quarter angle...I guess you can tell by me posting only 1 picture of the front...
c_dub is offline
Old 08-09-2008, 04:58 PM
phandango's Avatar
Nice.
phandango is offline
Old 08-09-2008, 08:30 PM
ExcelRevs's Avatar
they look good and beefy...
ExcelRevs is offline
Old 08-11-2008, 05:20 AM
2008XBlimited's Avatar
very nice. like the staggered look
2008XBlimited is offline
Quick Reply: New shoes finally---let me know what you think
