Nissan 350Z Wheels on a 08 xB?
Anybody know if the 5 spoke 350z wheels would fit on the 08xb????
I have a sw xb and was thinking if the wheels fit is painting the 350z wheels a flat black.
Any suggestions
Any suggestions
1st caps off, next check Google and see if they fit and if you do get the wheels and paint them flat black, I'm going to take the wheels off and beat you with them. You do NOT rattle can 350Z wheels! And just buy some aftermarket wheels instead, you'll save $.
I ALREADY BOUGHT WHEELS 18X8.5 STERN ST-2 TORUING BLACK WHEELS.
I WANT AN ALL FLAT BLACK 5 SPOKE WHEEL. THE ONLY AFTERMARKET ONES THAT LOOK GOOD ARE THE AXIS SUPER HIRO IN MATTE BLACK BUT I DIDNT FEEL LIKE FORKING OUT OVER $2000 FOR ATLEAST 18 WHEELS IS WHICH THEY GO FOR.
seriously. take your caps lock off and learn to google. i googled for 350z bolt pattern and found a plethora of information.
the standard 17" 7-spoke wheel is a 7.5 in the front and 8 in the rear with 30 and 33mm offset respectively. if you get these you should probably get a spacer to push it out to avoid rubbing the inside. the bolt pattern is 5x114.3 like the xB2 and they should bolt in fine. the hub bore of the 350z is 66.06mm so you should get some hubcentric rings to mate to the 60.1mm xB2 hub bore.
lessons of the day: google and turn off caps lock so you dont ____ everyone off.
edit: the rear is 8inches wide. and it turns out there are a lot more wheels than the standard 17". google the rest on your own.
the standard 17" 7-spoke wheel is a 7.5 in the front and 7.5 in the rear with 30 and 33mm offset respectively. if you get these you should probably get a 10-15mm spacer to push it out to sit flush. the bolt pattern is 5x114.3 like the xB2 and they should bolt in fine. the hub bore of the 350z is 66.06mm so you should get some hubcentric rings to mate to the 60.1mm xB2 hub bore.
i hate calculating offsets.. and yes thinking about it CIONIDE is right... at this low offset i think youre going to rub
I ran 17x9 +25 front 17x9 +15 rear on my Nissan Maxima. Of course I had rolled fenders and stretched tires but thats not even that aggressive compared to Lexus.
Scion is hella weak.
here's some pix of my Maxima and it's low offset back then.
