The OFFICIAL 18" Wheel Thread.... Let's see them
Old 02-22-2013, 01:31 PM
  #1021
Phobic's Avatar
some nice wheels showing up in here lately.
Phobic is offline
Old 02-24-2013, 03:36 PM
  #1022
Phobic's Avatar
Originally Posted by Big_Jim
Where you been man?!?!?
new job, not a ton of time to kick around on the forums anymore. Plus Im selling the xB to get into something else. Need a new, fresh project.
Phobic is offline
Old 02-25-2013, 09:21 PM
  #1023
devilon's Avatar
Finally put some new wheels on mine.
TSW Nurburgring in Matte Gunmetal 18x8 +35 with 225-40-18 Nitto Motivos.
devilon is offline
Old 02-27-2013, 01:22 PM
  #1024
Team XcelsiA
Team Sushi
06scioxb's Avatar
18" tC2 wheels
06scioxb is offline
Old 03-12-2013, 12:44 AM
  #1025
TattooAl's Avatar
Keeping the thread alive, learned lots of good stuff here.
Also, 52 pages later and didnt see anyone rockin the TSW's I just ordered, woo hoo !
Quick question, Im on a Sportline drop, 18x8 +40 rims on the way. Should I go with a 225/40/18 or give it a slight stretch at 215/45/18 ?
I dont wanna rub, or roll fenders, and might add a 10 or 15mm spacer in the rear eventually.....
TattooAl is offline
Old 03-12-2013, 01:16 AM
  #1026
Utah Scions
xseveredveganx's Avatar
You'll be fine with either tire.
xseveredveganx is offline
Old 03-12-2013, 01:18 AM
  #1027
TattooAl's Avatar
Thanks bro, i have a slammed gen1, and im a noob with the gen2, LOL !
On the gen1 we needed a 10mm spacer in the rear to make it flush with the front wheel. Is Gen2 the same or more?
TattooAl is offline
Old 03-12-2013, 05:12 AM
  #1028
Utah Scions
You can't be 'flush' and not roll the fenders. Well, it depends on your suspension. If you want to be as slammed as I'm assuming your gen1 is, you can't be 'flush' without a roll. You can trim the fender lip, I've heard of folks doing this.
Until I know what suspension you're planning on running, I can't recommend any type of spacer.
Just read your other thread. You could run a 10mm spacer in the rear to have an effective offset of +30 with the 18x8 wheel, but I'd wait until you get the wheels and tires on the car. See how it looks and then go from there. However, I'm pretty positive you'd be fine with a 10mm spacer.
Old 03-12-2013, 12:11 PM
  #1029
TattooAl's Avatar
Gotcha, I was thinking bout waiting til the wheels were on too, thanks dude!
TattooAl is offline
Old 03-12-2013, 12:15 PM
  #1030
TattooAl's Avatar
I'm gonna be running the same wheel specs on drop, do you have any rubbing issues on dips or with a full car? Fenders rolled? Thanks
TattooAl is offline
Old 03-12-2013, 01:03 PM
  #1031
TattooAl's Avatar
Guys with the 15mm spacers, do u need to cut/shave down the old studs to get the wheels to fit? With 10mm is there enough stud left to bolt on the wheels?
TattooAl is offline
Old 03-12-2013, 08:48 PM
  #1032
Utah Scions
I would recommend slip on spacers with extended studs. I'm running 10mm up front and 15mm out back with extended studs.
Old 03-12-2013, 09:09 PM
  #1033
GOLFHAK's Avatar
Al, with my TRD rims and DF210 springs I ran 15mm in the rear and they looked great no roll or anything. I had the Airrex airride installed and had to drop down to 10mm to get it to drop to the rim. Also different wheels but I think same offset,30. Here's a pick.....
Then
Now
Also, I didn't have to cut any bolts but as far as I know they don't make a bolt on 10mm like the 15. I had to put new extended studs which came with my spacers.
GOLFHAK is offline
Old 03-13-2013, 02:45 AM
  #1034
TattooAl's Avatar
So what you guys are saying is you had to do a stud swap?
TattooAl is offline
Old 03-13-2013, 02:47 AM
  #1035
TattooAl's Avatar
BTW Golfhak the ride looks sick !!!
TattooAl is offline
Old 03-13-2013, 03:25 AM
  #1036
Utah Scions
You don't have to do anything. However, if you decide to use slip-on spacers, I would certainly 100% install the included extended lug studs.
Old 03-13-2013, 04:16 AM
  #1037
GOLFHAK's Avatar
Thanks for the compliment Al, if you go with 10s I think you will but the 15s I had were available as a bolt on with studs . But if you're staying with springs for now the bolt on ichbans 15mm will work great, easy install.
GOLFHAK is offline
Old 03-13-2013, 04:27 AM
  #1038
TattooAl's Avatar
Yeah i had the 15mm Ichiba on my gen1 and we had to shave down the old studs a bit cause they were pokin past the spacer a bit and not letting us mount the wheel correctly. Had to take 1/4 inch off.
TattooAl is offline
Old 03-17-2013, 01:59 AM
  #1039
bignoog's Avatar
I'll be installing my coilovers next week but here she is as it sits. I'll be doing a re-barrel on the front wheels eventually.
bignoog is offline
Old 03-17-2013, 03:28 PM
  #1040
TattooAl's Avatar
like those wheels alot, post pics asap
TattooAl is offline
Quick Reply: The OFFICIAL 18" Wheel Thread.... Let's see them
