offset?
i believe scion sells a 19x8 with a 40 off set. I could be wrong about the offset. I am seen a few people here put staggard wheels already. I have seen 19x8.5 and 19x9.5 my concern is the offset. So far nobody has really posted the offsets that hey have used. I was looking at some stern wheels
It depends on a lot of factors.
It could clear the caliper, if the wheel has a med or high disc. If the wheel has a low disc, then it might hit the caliper and a spacer will be needed. That will on lower your offset even more.
You could very well run a +35 offset. That is a difference of 13mm. I say that the TRD wheels have some room to give to the inside edge of the fender. You could also go down on the with of the tire, say instead of running a 245, you could run a 235 and get about 5mm more of room.
Yes, if you put spacers on, they will lower your offset even more. If you have a +35 off, with a spacer it will be +30.
5mm spacers usually run about 6-10 dollars each and you don't need to put longer lugs in. If you go with 10mm spacers, they are usually around 70 dollars for two and they require longer lugs. The lugs are easy to replace if you have the right tools. H&R make good quality spacers, if you want 10mm or higher. If you want just 5mm, I seen them at the local auto parts store for cheap.
I have ran 5mm spacers on my Lexus for 3 years without any issues.
Axis Xb offset
I am going to call Axis wheels tomorrow and see if I can get someone to tell me the specs on their Xb from the photos someone put up the other day. I am curious as to what size they are using as well as how the B was lowered. Will post if I have any luck..
xBrelease08
Scion xB 2nd-Gen Wheel & Tire
12
02-29-2016 05:39 AM
umnitza
09-01-2015 08:06 PM
