painted the hubcaps lol
Old 04-23-2008, 01:14 PM
  #61
DJ_FroZone's Avatar
Originally Posted by longboardluv
frozone, they have that paint that changes color depending on the angle of the light source. that might look good on your BSP
linkage?
DJ_FroZone is offline
Old 05-05-2008, 01:15 AM
  #62
memebag's Avatar
I painted my wheel covers yesterday. They don't look anything like I wanted them to. I bought the black Fusion spray paint and I followed all of the prep steps detailed in this thread. I wanted a nice, glossy black, but I got a dusty sort of matte black.
What am I doing wrong? Why can't I use spray paint like regular people?
memebag is offline
Old 05-05-2008, 05:51 AM
  #63
miketf1's Avatar
make sure you use gloss black.. a dusty look is probably cause you used matte black
sometimes there are idiots that swap caps and make life difficult for everyone.
miketf1 is offline
Old 05-05-2008, 01:18 PM
  #64
memebag's Avatar
I used the paint with the shiniest black cap I could find. There was one that looked glossy, another that had "SATIN" written on it and looked less glossy. I picked the glossy one.
I think I'm doing something wrong.
memebag is offline
Old 05-05-2008, 02:52 PM
  #65
longboardluv's Avatar
well it might be because you didn't put enough coats. I ended up using 2 cans to do all four of my wheel covers. And i think a 3d might even make it more shiny. It takes a while to get enough light coats on there before it becomes shiny.
longboardluv is offline
Old 05-05-2008, 11:34 PM
  #66
memebag's Avatar
I used 2 cans. It never got shiny. Each coat made it look dustier and dustier. I let them dry for 10 minutes between each coat. Then I let them dry for 24 hours after the last coat. After 24 hours if you touched them you got black dust all over your finger.
memebag is offline
Old 05-18-2008, 01:06 PM
  #67
HypnoticTealMica's Avatar
Dust after they are dry? That is wierd.
First you need to paint on a dry day. Humidity in the air will screw up any DYI paint job. Wear a simple respirator... from hardware store. You only get 2 lungs in life.
I generally clean an object I'm painting with rubbing alcohol, then dull the finish with fine steel wool. That gives the finish "tooth" for the paint to grip to.
Rinse again w/ alcohol.
Spray 1st coat VERY light... it will not cover all the underneath finish.
Let that 'tack' for a few minutes.
Spray the 2nd coat same as first, covering all the original finish.
These coats will not look shiney but dull & rough.
Spray the final 3rd coat "wet", almost to the point where it runs.
The paint will set up fast so cover the whole area quickly.
This coat will be very shiney & smooth... and will dry that way.
Let everything dry for at least 3 to 4 drys.
The paint will "out gas" during this time so find a dry space not in a living area.
Best tip I can give is PRACTICE this on sraps of similar material until you get the results you want. I've messed up lots of projects but it's all part of learning.
Good Luck
HypnoticTealMica is offline
10spokess
08-16-2015 02:50 AM
mc1114
Scion tC 1G Aero & Exterior
08-10-2015 10:34 AM
JoggerFogger
Photography & Video
07-27-2015 09:34 PM
umnitza
07-25-2015 07:54 PM
Quick Reply: painted the hubcaps lol
