quick Rim question
Old 07-08-2008 | 01:51 AM
Andydeelight's Avatar
Default quick Rim question
I just bought a set of Axis Gravity rims 18x9 with a +40 offset.
If I put these on will the rim go past the fender, and is there absolutely no way that a 18x9 will not fit the front end
Old 07-08-2008 | 02:35 AM
CIONIDE's Avatar
I haven't seen anybody pull off 18x9 on the front. I wouldn't try it.
Old 07-08-2008 | 02:55 AM
detroitbassxb's Avatar
You bought rims before even confirming that they would fit?
Old 07-08-2008 | 03:00 AM
coryjames's Avatar
they will fit only if you get ksports and camber the heeelllllll out of the front
Old 07-08-2008 | 03:14 AM
CIONIDE's Avatar
If you must have Axis Gravity wheels, then you need to send them back and get the 18x8 +35 offset.
If you're OK with staggered, then keep the 18x9 +40's for the rear (they're fine); but you need to drop to 18x8 for the front.
Old 07-08-2008 | 05:54 AM
The Rims were a gift. The person who bought them was told they would fit. I guess I should just shine away from the nines. Thanks for your help I trust you veterans.
Old 07-08-2008 | 08:19 AM
CIONIDE's Avatar
Like I said, the 18x9 +40's will work fine on the rears if you're OK with going staggered and not being able to rotate your tires. All you have to do is swap the fronts for the 18x8 and you'll be fine..
If you want all 4 the same, and to be able to rotate, then you need to drop down to the 18x8 +35 all around.
BTW, anybody who gifts you Axis wheels is a great person, even if they didn't know everything about fitment.
Old 07-09-2008 | 09:08 AM
BBN-Boys's Avatar
I wish I could get gifts like that also..
bootlgr
01-26-2016 02:22 AM
Greg S
05-28-2015 01:46 AM
Scionxa180
03-13-2015 05:39 AM
TotalChaos
13
02-04-2015 11:24 PM
akwdcaveman
Scion tC 2G Wheel & Tire
01-17-2015 01:47 PM
