Tire pressure?
The pressure info on the tires is only the max, it doesn't tell you what you should be running and definitely don't run it.
Unless the tread patch on the different tire is significantly larger than OE, you should just stick with the OE pressure. Otherwise, you can either ask the tire manufacturer for their recommendation for your car, or you can grab pencil and paper and calculate it given the OE tread patch and pressure (have fun ). Personally, I'd just stick with the OE spec unless I changed to slicks.
Some of this info would seem to be common knowledge, but I thought a thread devoted to tire pressure would be a good place to put it:
http://www.tirerack.com/tires/tirete...e.jsp?techid=1
http://www.tirerack.com/tires/tirete...e.jsp?techid=2
http://www.tirerack.com/tires/tirete...e.jsp?techid=3
http://www.tirerack.com/tires/tirete....jsp?techid=72
http://www.tirerack.com/tires/tirete....jsp?techid=73
http://www.tirerack.com/tires/tirete....jsp?techid=74
http://www.tirerack.com/tires/tirete...jsp?techid=147
This may sound crazy-
I have checked the air in aftermarket tires by:
On a dry day - taking some chalk and putting a line across the tread and drive a short distance. Then check the chalk line and you want to be able to see that it has evenly worn away. If the center has worn, then you have too much air in the tire and if the outter part of the line is worn, then you have too little air in the tire.
I hope this helps.
I hope this helps.
kingofthecrate
01-21-2015 09:28 PM
