TPMS fix.
TPMS fix.
Here's my contribution...
I had aftermarket rims and apparently the driver side rear sensor died and the dealer wanted my second born to replace the sensor. After driving around for 3 months with the annoying light and researching the web. I finally found a fix to get rid of the annoying light. Note the fix is to make the low pressure light from coming on. It still store the DTC code but won't trip and CEL.
I been reading the Yaris forums and it look like the car uses the same TPMS ECU as the xB. I'm sure this fix will also work.
http://www.yarisworld.com/forums/sho...9&postcount=45
Here's the link to the PDF I made.
http://www.aprilia-v60.net/user/Scio...TPMS%20fix.pdf
Let me know if this work for any 09's xB's and other similar vehicles.
I'm sure it does. The pink wires goes to the instrument cluster and it need a 5volt to keep the light from coming on. The black wire next to the pink is a 5volt source. Just jump the two wires together.
kleecker
Scion xB 2nd-Gen Wheel & Tire
05-22-2016 06:10 AM
