TPMS re-initialization help
New to the group, 2nd time Scion buyer. Recently bought the 08 XB. Had new wheels put on. In the process, the tire place broke one of the sensors, so they had to get me another one in which they got from the dealer. Only problem is the light is still on due to the new sensor. The manual states when replacing a sensor it must be taken to the dealer. I don't buy that. There must be a way (disconnecting battery for _ amount of time, etc.) so that I can bypass the dealer. Any help?
Sorry, but it does need to go back to the dealer.
Each sensor has a unique seven digit serial number. All 4 of the car's serial numbers need to be programmed to the TPMS ECU in the vehicle. The dealer must use his scan tool to do this writing.
Hopefully the tire shop recorded the serial number of the 'new' sensor. Otherwise, the dealer will need to break down the tire to read the serial number off of the body of the sensor.
Ok I have yet to confirm if you must take back to the dealer will find out tomorrow. If so I would make the tire place that broke to orginal sensor pick up the bill it was their mistake breaking the sensor not yours. Thats why they get paid to do a professional job. Trust me make a stink and the tire shop will pay that cost for you.
Thanks for the answers to all. For those who asked, yes, I did try the reset button. But again, the manual stated for a replaced sensor it HAD to go back to the dealer. For those who answered it must return to dealer, do you know if all 4 tires would need to be dismounted to do this or can it be done without removing the tires?
P.S. The shop who broke the sensor will be paying for this...it has already been discussed.
As long as you can tell the dealer which tire has the new sensor, that will be the only one they need to break down.
They can use the scan tool to determine which 3 sensors ID's that are written to the ECU are still with the car (the ECU will see signals from those three). The dealer can then replace the one ID that is not detected with the new ID.
For those interested, the dealership ultimately reprogrammed the new sensor and now i'm good to go. it cost the tire shop $100. i'm sure that's a mistake they won't make often!! Thanks again to all of the results.
good to hear!
yea... did the shop have to take apart the wheel to get the new sensor's serial number? or were they smart enough to write it down before putting it in?
Nah, the shop wasn't smart enough. I called the shop to see if they had the old sensor or kept the box the new one came in and the answer was no to both. So the dealer had to break it down...didn't bother me as I wasn't paying for it.
kleecker
Scion xB 2nd-Gen Wheel & Tire
05-22-2016 06:10 AM
