Valve Stems
Valve Stems
Newb question..........
I’m planning of have a set of custom 19” wheels that will not have the TPMS valve stem on. What other type of valve stems is available? Is the standard cheap stuff rubber valve stems ok? Or is there a better alternative or upgrade?
I saw some metal ones also. Are these better or recommended?
btw..... Can someone confirm that the .453" rim hole is the size we need for most of our applications on our wheels.
And.... I think the 1-1/4" valve stem length is OK. Can someone please confirm this?
Thanks.
Thanks.
Standard el cheap valve stems work just okay. Those metal ones are made for different types of wheels and *may* not fit the stock steelies. I work at a local tire shop and switched my TPMS sensors to my 18s and they work just fine. The steelies have Blizzaks and those rubber stems and are holding just fine.
Thanks for the input. It's always good to hear it directly from a person that has first hand experience and expertise.
I actually went to one of our performance parts shop and they basically told me the same thing. Generally, the metals ones work great, but they do not work for every application. The wheel design (spoke placement, hole placement, lip placement, etc) has a lot to do if it will work or not. They also told me that the standard rubber ones usually works just fine, but is more susceptible to leaks since it's forced through the hole. The metal one, which are bolted on, tend to have a better seat and seal.
At work, we only replace them when A. We replace the tires B.They are old and weather rotted.
With that said, you shouldn't have any problems. Especially being out in California with no snow/salt/crazy oxidization. I've seen many chrome wheels being pitted and peeling from salt.
You had to know I was going to jump on that one vegan!
Chrome or go home!!!
I'm actually looking into the 5AD S5:F's in stealth chrome... I don't run chrome in the winter. Learned my lesson with some 20's that pitted on me in 2 months of sitting on my truck in my driveway... They didn't warranty them.
I like the 5AD wheels also, but I want 18x7.5 or 18x8, and they don't come in those sizes.
(Sorry for the threadjack BBN-Boys.)
I like the 5AD wheels also, but I want 19x8.5 or 19x10.5, and they don't come in those sizes.
Don't edit the quotes!
As my father says, everybody likes a smart guy, but nobody likes a smarta$$.
I do wish they came in 18" sizes though, I don't want to step all the way up to 19". I'd actually go with 17" wheels if I didn't think they look too small against the big slab sides of the xB2.
steeze69
05-24-2021 02:57 AM
