What is the widest tire & wheel for a RS 7.0?
Old 09-02-2010 | 04:52 PM
PursuitSS's Avatar
Default What is the widest tire & wheel for a RS 7.0?
I just purchased a new 2010 RS 7.0.
I would like to know what is the widest tire and wheel I can run front and rear. I have seen posts about running a 9.5" wheel in the rear. I would like to stay with either a 17" or 18" wheel (we have a LOT of pot holes in our town). The wife has already told me that I can't modify the wheel wells.
Thanks.
Old 09-02-2010 | 06:52 PM
ariese's Avatar
the wife told you that you cant?
back hand her
Old 09-02-2010 | 06:55 PM
PursuitSS's Avatar
back hand her
Considering her proficiency with a firearm, that WOULD be fatal!
Old 09-02-2010 | 07:18 PM
matt's Avatar
You taught her to use a gun? Back hand yourself!
Old 09-02-2010 | 07:20 PM
PursuitSS's Avatar
Worse yet, not just ANY gun................an HK MP-5 9mm submachine gun!
Old 09-02-2010 | 07:21 PM
papo's Avatar
if its your daily and u have a family just go 17/18 x8 or 8.5 with a 225 or 235/40 for 18s [45 if your running 17s]
Old 09-02-2010 | 08:02 PM
Greg S's Avatar
I like the 18x8 with a 225/40R18 on the front with a 40 offset, that is basically just tucked in the edge of the fender. Any wider or lower offset and you'll poke out some. For the rear you can go with a wider rim or lower offset. About a 10-15mm lower offset or a 9.5" width rim will come out almost perfectly flush. Or you could just add some 10-15mm spacers and run all four rims the same size. Much easier for rotating tires. All of this is dependent on how high you want to have the vehicle. I keep mine aired up about 1 1/2" above the tires so that the front doesn't rub on hard corners or large pot holes and so that it'll clear the slope up the driveway.
evolving_machine
Scion xB 2nd-Gen Wheel & Tire
12
01-18-2016 09:41 PM
scionlife
371
06-03-2015 12:00 AM
kingofthecrate
01-21-2015 10:28 PM
toyotaisme
01-10-2015 11:24 PM
scioninla
10-30-2003 09:01 PM
