Will Acura RSX rims fit our cars?
Old 07-27-2010 | 04:33 PM
D_Unit's Avatar
Default Will Acura RSX rims fit our cars?
Specifically, is the hub bigger than our 60.1 so I can just buy a hubcentric ring to compensate for it? I know the bolt pattern and offset is okay...
Old 07-27-2010 | 04:48 PM
ack154's Avatar
If the bolt pattern and offset line up, then yes, you should just need some hub rings of the correct sizes to center it all up.
Old 07-27-2010 | 04:53 PM
D_Unit's Avatar
Okay, can someone confirm if the RSX wheels have a hubcentric bore of 64.1mm which is SLIGHTLY bigger than out 60.1mm bore.
SO, since no one makes a 60.1mm - 64.1mm hubcentric ring, would I be fine to run the rims WITHOUT them since the difference is only 4mm or will my wheels wobble???
Old 07-27-2010 | 04:58 PM
ack154's Avatar
Two different forums I've read (so far) claim the 64.1 mm. And check the "vehicle information" box at the top left of this:
http://www.streetdreams.org/wheel-fi...rtby=&start=19
I think you're OK there. I can't help you on the running with/without rings though.
Old 07-27-2010 | 05:01 PM
D_Unit's Avatar
Thanks ack for the ack-knowledgement. Hopefully someone can comment on the hubcentric situation.
Old 07-27-2010 | 05:26 PM
CIONIDE's Avatar
2nd-Gen xB on 05-06 RSX wheels:
https://www.scionlife.com/forums/sho...d.php?t=157817
60.1 - 64.1 hubcentric rings:
http://www.justforwheels.com/index.j...cat=hubcentric
Old 07-27-2010 | 05:38 PM
D_Unit's Avatar
Originally Posted by CIONIDE
Thanks CIONIDE. I passed on these rims before cuz I thought it wasn't possible, but I'm gonna shop for them again.
Old 07-27-2010 | 06:00 PM
CIONIDE's Avatar
You have PM.
Old 07-27-2010 | 11:54 PM
xseveredveganx's Avatar
Utah Scions
I had a buddy that was going to set me up with a set of TL Type-S wheels for a helluvadeal. However, I never contacted him back and the wheels are probably long gone.
Old 07-28-2010 | 03:08 AM
xB Cracker's Avatar
Those plastic rings don't last too long. When I put AMG wheels on my Passat, I had a machine shop make them for $50 out of aluminum after the plastic ones cracked after 500 miles.
Old 07-28-2010 | 06:29 AM
CIONIDE's Avatar
It must depend on the quality. My rings hub are not metal, and they've been fine for 25k miles. I just saw them about 2k miles ago when I had my brakes done, and they weren't cracked at all.
minter66
12-15-2014 02:45 PM
royder1976
10-10-2003 05:57 PM
royder1976
10-08-2003 04:12 PM
