will running 19x9.5 on rear rub?
im planning to get a set of ISF knock off wheels off ebay but the rears are 19x9.5. A little more aggressive than the original ISF wheel. I plan to drop my xb with either eibach sportline or trd springs so any feedbacks will be appreciated.
Only way that you'll rub, is if you have a full load and it would more than likely be on bumps. Rolling fenders isn't that big of a deal. At all. Nothing to avoid. Bolting on a new wheel is worse than rolling a fender. Just my $.02.
CIONIDE can confirm if it will fit without any type of modification, but I think you'd need a roll for sure.
You can run a 9.5, but +45mm offset along with a 235/35R19 tire, with no modifications.
it wont rub i'm running 19x8.5 and 19x9.5 37 off, 4 adult and a baby with TRD... dont know how to link but you can see my post somewhere
edit: here you go
http://s1126.photobucket.com/albums/l612/ntm1028/
edit: here you go
edit: here you go
edit: here you go
19x9.5 +35 on the rear with 235/35 tires should be OK with TRD drop, but Sportline drop will require rolled fenders and/or stretched tires. What are the front wheel specs and anticipated tire size?
What do you think of running a 19x9.5 +40 front and rear? I just dropped it with df210's. I just don't think the 19x8 +40 give me the dish I'm looking for. I don't want to roll the fenders so I may be stuck with the 19x8's.
Why don't you want to roll the fenders?
You should be fine with a 235/35R19 tire, but may rub occasionally if you don't roll the fenders. I have a buddy that was running 19x9.5 +45mm with 235/35R19s and on DF210s without a problem at all. He's running that same spec on the front with not a single issue.
So yeah, you should be fine.
I guess I should have said I prefer not to have to roll the fenders. The other option is 19x8 +40 front and 19x9.5 +40 rear. I am having a lot of trouble deciding on wheels. Originally I was thinking 18x8.5 +40 all around but I can't decide. I like the look of the 19's better but I know I will get a better ride from the 18's.
