Motor oil question
Motor oil question
I took my car to a Toyota dealership for its first oil change since I bought it. Wen I got home, I noticed the sticker they placed on the windshield stated they used 5W20 oil. I seem to recall the manual calls for 0W20. I know this is not a big difference, but should I go back and ask that they do it right?
EDIT: I checked the manual and I guess 5W20 is also OK, though Toyota recommends 0W20. I'm no expert on motor oil, but I don't see why I wouldn't use 0W20 instead of 5W20. It's not all that cold in Atlanta these days, but if I understand oil grades correctly, a 0W20 would help reduce engine wear when starting and otherwise would do the same job as any xW20 once the engine is warmed up. I did specifically ask for 0W20 oil, so I will probably not go back to this dealership (I have had other negative experiences with them too, so this is just another ding).
0w20 is more used for the colder, winter climates...
5w20 is actually the toyota standard and recommended weight. they did nothing wrong and that weight will actually protect the engine better during warmer climates when the car hasn't warmed up yet...
So would there be ANY advantage in using one vs the other? I read somewhere that the higher the difference between the two numbers in a multigrade oil, the more 'sludge' it will produce?
What about synthetics? Is there a real advantage or not really worth the extra $?
Well worth the money, especially since you can stretch out your oil changes much further than you can with mineral oils.
Originally Posted by Bender_xD
is there a general concensus on this forum about which BRAND synthetic is the best for our engines?
I recommend going for one that is mostly ester based, such as Mobil1, Redline, or Amsoil.
I recommend going for one that is mostly PAO/ester based, such as Mobil1, Redline, or Amsoil.
haha i know i'm asking for it, but oh well. I could go in any direction w/oil at this point, someone just make my mind up for me please.
I've heard many good things about Mobil1. If someone can convince me on something else go ahead.
I switched from redline to amsoil (just because I am able to get it for less) and haven't noticed any difference (which isn't a bad thing). Ever since I put my supercharger on, I have fun synthetic.
Here's an excellent post over at My350Z.com with tons of info about motor oils. Click it if you have no idea what Esters, PAO, and Group 3 are.
http://my350z.com/forum/engine-and-d...-and-info.html
06ScionTc5sp1
9
10-16-2020 01:18 AM
