Short Shifter Question
Old 12-24-2008 | 01:14 AM
drewm389's Avatar
Default Short Shifter Question
Could a short shifter mess up anything even if it broke? Also, can any one vouch for the nst short shifter.
Old 12-24-2008 | 09:05 AM
TRDxD's Avatar
go read up on the NST short shifter thread, plenty of good feed back from it. and yes..you can "mess up" a lot if your short shifter breaks...imagine how your engine will run if the shift link disengages...because that's exactly what happens lol. but there should be nothing to worry about...install is easy, and the quality of the product is good.
Old 12-24-2008 | 09:07 AM
TRDxD's Avatar
https://www.scionlife.com/forums/viewtopic.php?t=206836
theres the short shifter thread...just to make it easier on you
Old 12-24-2008 | 06:26 PM
drewm389's Avatar
Appreciated!
Old 12-24-2008 | 06:59 PM
TRDxD's Avatar
np man!
Old 01-02-2009 | 10:05 PM
RAGE's Avatar
Default Re: Short Shifter Question
IMHO, the NST is a budget part. The TRD has more parts and is engineered to avoid wearing the link cables. The NST shifter is just the linkage modification and causes the cables to bind a little bit. I have driven bothe the NST on a friend's car and have the TRD installed on mine. The TRD is a more complicated install, but the end result is really noticeable. My xD shifts smoother than his and just "feels" better.
Old 01-02-2009 | 10:51 PM
TRDxD's Avatar
I'm not trying to dispute what you're saying, but honestly the parts are the same...if you look at the TRD and compare it to the NST, they're almost identical in shape, and require the same installation process...read the installation guide from sparks toyota, then the installation guide someone wrote here on the forums for the NST, it wouldn't make sense for them to be any different.
Old 01-03-2009 | 01:54 AM
XDME's Avatar
The TRD comes with a new cable guide it is machined aluminum compared to the factory cast iron part. The TRD cable guide straightens out the cables. True the TRD and the NST shift lever cam are the same, but I believe the NST does not come with the cable guide.
Old 01-03-2009 | 01:59 AM
TRDxD's Avatar
hrmm if that is true then that clears it up...i never saw anything about a cable guide for the TRD Shifter though..oh well! sounds good to me
Old 01-03-2009 | 03:47 AM
mcbrew's Avatar
'tis true. I don't have any experience with the NST, but the TRD one does come with the new guide. I made sure of that when I picked my car up from the dealership. The shifting is AWESOME compared with the stock setup. HUGE difference!
Old 01-03-2009 | 04:25 AM
drewm389's Avatar
that may be true but nst is still a bunch cheaper and noone has complained about them yet and you cant argue with that...
Old 01-03-2009 | 07:54 AM
TRDxD's Avatar
that's basically what led me to believe there was no difference (that and i had never seen the cable guide listed in the set for the TRD shifter) but...i guess that's what you pay more for. interesting indeed! i plan on purchasing a quick shifter as well...guess ill be getting TRD if it comes with the new guide
Old 01-04-2009 | 12:22 AM
PHATBLK's Avatar
It's a bunch cheaper and you get less. Try a TRD SSK and you will agree that it crisper and the shift map is more intuitive. Neutral feels the way it should - loose.
Old 01-04-2009 | 04:30 PM
TheJonas53's Avatar
What does the cable guide look like? Can it be easily hand made? Like getting some parts from Home Depot and modifying them.
Old 01-04-2009 | 07:05 PM
PHATBLK's Avatar
Anything is possible, but this part is milled from a piece of aluminum with irregular precision cutouts for the cable stops / irregularly spaced bolt holes.. If you could do this at home, I would shake your hand, but I would consider you a little odd. It would take much more effort than the delta between the NST / TRD prices.
It's possible that the part shows up in some Toyota / Scion parts list?
Old 01-04-2009 | 07:23 PM
TRDxD's Avatar
not even on the installation guide does it show up, thats why i had no idea that it was even part of the kit. but i agree, i would like to know what it looks like. guess ill find out when i get the kit
Old 01-04-2009 | 08:18 PM
drewm389's Avatar
id like some pics when you get the kit please.
Old 01-04-2009 | 10:50 PM
TheJonas53's Avatar
Yeah x2 on that. Make sure to get a picture of this guide and what its made of.
Old 01-04-2009 | 11:27 PM
XDME's Avatar
I hope the following pictures help:
These are part of the instructions:
This is the factory (stock) guide:
This is the top view of the factory guide - notice how it angles the cables:
This is how the TRD cable guide looks in place - notice the cables are parallel:
[/img]
Old 01-05-2009 | 03:02 AM
TheJonas53's Avatar
Thanks for the pics.
So the only difference is that it just straightens out the angle of the cables?
Quick Reply: Short Shifter Question
