xD oil change
Drain Plug: Clean it and install it with a new gasket. Torque: 37 N*m (377kgf*cm, 27 ft.*lbf)
Oil Filter Cap Torque: 25 N*M (255kgf*cm, 18 ft.*lbf)
Capacities
with oil filter change: 4.4 US Quarts
without oil filter change: 4.1 US Quarts
dry fill: 5.0 US Quarts
Capacities
Somebody on this forum said this Sears tool fits the xD filter body.
http://www.sears.com/shc/s/p_10153_1...ord=oil+filter
Haven't tried myself tho.
Did my first oil change tonight. Drained it out, and let it drip dry then filled it up with 5w20 royal purple synthetic. No problems getting anything apart, bought a 65mm end cap wrench from Advanced Autoparts for $4 and change. Only problem I had was getting the original metal gasket/washer off the drain plug. It sort of dry-welded on. I eventually grabbed it with a pair of channel locks and it popped right off.
Very good info guys I noticed the new cartridge when I had the car jacked up taking a look at things. Searching to see if pure 1 or wix has a cartridge available for it yet. Will let you all know asap.
The filter part number for purolator will be L16311 but is not yet available to the public.
The Dana / Wix part number will be... Also not available yet.
http://www.wixfilters.com/filterlook...asp?Part=57064
k&n does not list a fiter as of yet.
Last item, you can buy a 10 pack of oem filters from TRD sparks for $35.50! WOOHOO!
http://www.trdsparks.com/displaypart...&parts_id=2129
Because I was doing it from a phone, was faster to just make a new post, and besides that I felt like it whinebag
And to further help that vein pop out on your forehead, I also made a seperate thread about the cartridge filter itself Hope this does not destroy your perfect night *LOL*
https://www.scionlife.com/forums/viewtopic.php?t=224757
maintenance required light
[quote="speedoguy"]
1. Trip A instead of ODO selected on the multi function display
2. Turn key to OFF position
3. Hold down button while turning it to ON position.
4. Trip A will go to zero and back to actual mileage after 5 seconds.
Thanks it worked like a charm. No more annoying maintenance required light. [/b]
Originally Posted by Stupidhaole
Originally Posted by speedoguy
does anyone know how to reset the maintenance req light ? the instructions in the book are wrong
Recently while changing my oil and filter late at night, I forgot I didn't have a tool to twist open the plastic filter cap, so I improvised and used a coilover wrench key. It took a few revolutions to loosen the cap for the first time, but it worked.
Used a 65 mm filter wrench from Advance Auto for the casing. Worked like a charm, though I spent a good bit of time bashing my knuckles against the oil pan trying to loosen the casing in a clockwise motion. Relatively painless once the gremlins of the oil change were worked out.
