Temperature Knob light
Temperature **** light
is it possible to replace the bulb on the temperature selector ****? mine appears to be out. I kind of looked at the **** from the back but didn't see an obvious bulb. Is there a schematic?
Thanks
AW
Thanks
AW
If it's the light for your ac temperature control, then it should be just a basic LED. The hard part is disassembling it. You would have to take apart your waterfall almost as if you were going to paint it. The **** itself should be a standalone piece once removed, you just have to take the back off. If you can get a replacement LED, that's fine, but if you're going through all the trouble, I say replace the LEDs in all the ac *****. Oznium.com has some inexpensive ones, the PLCC2, and you can choose what color you want.
travisbklein: Here's a diy on removing the waterfall. The videographer doesn't replace the bulb however you can probably visualize it with the temp control panel removed.
https://www.youtube.com/watch?v=rD-tvQ6Jo0A
yep once you take off the mechanism that does the dial part you can take off the lights with just a flat head, since mine went out I decided to order the t4 led purple lights
NonStopTuning
06-29-2015 08:42 PM
Green_rino
Scion FR-S ICE & Interior
01-20-2015 02:41 AM
