light on a/c button
light on a/c button
I noticed yesterday that the light that normally turns on when I push the a/c button doesn't work anymore....anybody have any idea if that sort of thing is easy to fix, or if it would be something the dealership would take care of? Its not really important, but if its not expensive/pain in the ___ to fix, I'd rather have it working. Thanks
I'm guessing you've tried it when the fan is on and the temperature setting is in the blue? If not, check that. I think there was something funny like that which you had to do in order for it to turn on. Does the A/C turn on? Might be thinking too hard into this, but LEDs rarely go bad..that's all.
I had this happen in my tC once and it was due to having the airflow set a certain way.... Basically, your car can't take in air and blow it back out of the same vent...
Once I changed how the air was set to circulate then it worked no problem.
I tried all the suggestions at once, and the light is back on...not sure what i did, probably since its the time of year when its cold in the mornings and hot in the afternoons I forgot to switch on of the settings when I was switching back and forth between heat and AC. Anyway, thanks very much! Glad I didn't take it in to be looked at, I'm a doof.
SkillFreeJake
Scion tC 2G Aero & Exterior
07-27-2015 12:34 AM
randompacking
01-28-2015 11:43 AM
Green_rino
Scion FR-S ICE & Interior
01-20-2015 01:41 AM
