Running rust on disc brakes
I noticed when I cleaned my wheels with Meguiers wheel cleaner that my front brake rotors started to rust. This is only surface rust and I know its normal for rotors. My question is "What is a good cleaner to help with the running rust?" is simple green or purple power ok to use?
Re: Running rust on disc brakes
I dont think the pad cleans the entire rotor surface.
If it's killing you, try some CLR (available at Home Depot and many bigger grocery stores) Use a stiff brush and some CLR - let it sit for a few minutes, repeat scrub - should clean it off.
evolving_machine
10-21-2023 01:16 PM
