Tire Size
Tire Size
xB 16 inch accessory wheel:
wheel size: 16x6.5J
offset: 45 mm
lugnut pattern: 5 lugs at 114.3 mm dia
tire size: P205/55R16
xB 17 inch accessory wheel:
wheel size: 17x7J
offset: 45 mm
proposed tire size: P225/45R17 Dunlop SP 5000 all season tire. Currently
front tire of the Lexus IS.
xD 16 inch accessory wheel:
wheel size: 16x6J
offset: 39 mm
lugnut pattern: 5 lugs at 100 mm dia
tire size: P195/60R16
wheel size: 16x6.5J
offset: 45 mm
wheel size: 17x7J
offset: 45 mm
wheel size: 16x6J
offset: 39 mm
k
Thanks for the info. Quick stupid question, when you up size a tire does it affect the offset or does the offset stay the same regardless. I'd be keeping the diameter close to original size going up to 17 inch wheels.
I am no expert, only reciting the info given to me from Scion, but I THINK the wider the wheel you put on the less offset you run, but it shouldn't have anythinhg to do with the height of the wheel and tire . . .
any experts care to comment?
I hope someone does comment. I've been reading about offset on the net but I can't seem to figure out what offset wheel I should get with a 17x7 wheel. The only wheels I have found of any size with a 39mm offset has been BMW wheels.
The wheel with 39 offset will "stick out" 6mm further out than the same wheel with 45 offset. 6mm = 1/4". Considering how much safety margin manufacturers put in the wheel sizing (allowing for tire chains and such), running 39 offset on a 17x7 wheel should be pretty safe on the new box.
Music City Scions
The replacement size tire for 17X7inch wheels going off shorbergs info would be 215/50/17. It would only be .3 inches taller or 1.3% taller overall than the stock 16" set up.
Music City Scions
Originally Posted by zoltiz
225/45/17 would be a much closer fit for a 17" wheel on the xD. Plus more rubber on the ground.
so will these fit...?
I have a 2001 Solara that I will be trading in for a Scion xD (I fell in love with 'em the first time I saw them. 2 family members have xAs and we all love them). I recently bought new Bridgestone Potenza G 009 all around, sized at 205/60HR-16. These should be able to be thrown on to an xD, even though the stocks are 195/60=16, right? (And i guess, those tires should be able to go on to my Solara, shouldn't they?)
I saw a pic of some basic 16" alloys on an xD, they were 6-spokes I think and looked really sweet... anyone know what the optional alloys will look like? (no chrome plz!!!!)
DelMarVa
Scion Tuners
Here is a sample picture of what wheel offset is.
The higher your offset is (Scion xB = +45), then your mounting face (lug circle) will be outside of your centerline, if your offset is negative (-22), then your mounting face will be inside your centerline.
