Scion xD Suspension & Handling Coilovers, Shocks, Airbags, Swaybars...
my experience with ksport coilovers.
Old 02-18-2011 | 10:43 PM
xD_kidd91's Avatar
Default my experience with ksport coilovers.
I hate it! well not exactly. mybad if I don't kno the name to all the parts of the car but I tried adjusting the height to make it lower but do to (im assuming) dirt and debris. this piece is completely stuck
so now im stuck with one side one inch lower. They said to use wd40 and smash it with a hammer to losin it .. ima give it a try tomorrow
how do you guys adjust height? im new to this and i bought these about 4 months ago. I heard that the new ones doesn't have that center piece that was pointed out. is that true?
Old 02-22-2011 | 03:08 PM
xDTool's Avatar
PB blaster is your friend, when i adjust height on mine , i cover the entire threaded cylinder with PB Blaster, take a clean rag and wipe off in 3-5 mins, repeat until the coilover is spotless, and its like adjusting a brand new strut. if you adjusted it on a dirty coil last time then thats probably why its seized, so yea you'll want to put some pb or wd-40 and a rubber mallet.
and of course make sure you loosened the hex screw that locks that piece (in case that slipped your mind)
Old 02-23-2011 | 01:23 AM
xD_kidd91's Avatar
Yea I'm aware of the hex key but even after having it unbolted; it would still be tight on but thanks. People been telling me pb blaster works well. Unfortunetly wd40 doesn't.
Old 02-23-2011 | 02:13 PM
xDTool's Avatar
yea after you loosen the hex try to get the spray down into the seized threads, then a few light smacks with the rubber mallet should help if it doesnt unseize itself just from the PB
yupinmytC
22
07-27-2024 08:08 PM
ScionDP
Scion tC 2G ICE & Interior
11-05-2015 10:59 AM
JonnyBigBoss
09-26-2015 09:31 PM
rmz489
09-16-2015 09:19 PM
